- Dec 30, 2013
Just got my velpads today. Not sure I want to take them off to compare with the velours I replaced then with. Too damn comfy!
So for those of you who run your HE-400 from the speaker outs of vintage amps - how safe is it volume-wise? my stereo is rated at 120W per channel @ 4-8ohms so I don't want to blow out my HE-400 after i start to touch the volume knob from 0!
I have been wanting a set of the vegan pads but they are just so expensive! I might break down and buy it though.
I just swapped to the velour from the pleather again. I'm not coming directly from using my SZ2000 this time around, so I can make a more fair call on the sound.
The bass isn't as decreased as I thought when switching from the pads but there is definitely a loss in the sub bass thump. It's still there, but not as present.
Everything else sounds smoother & more open in comparison, especially the highs. There is a more airy quality to it than the pleathers. I hear what you mean about the pleathers making treble sharp now though.
I'm very happy listening with the velours right now although I am missing a bit of the bass impact from the pleathers. The velours do make a more proper seal though.
In any case, it's all subjective, and we all have different favorite parts of the HE-400 sound, but I will admit I'm enjoying the velour more than I did last time, maybe the key is not switching to these right after my maximum bass phones
Velours are kind of itchy though. need to find a way to fix that. that is my main complaint with them, really.
As someone who has actually tried all he mentioned pads, I will again state the vegans are the best in comfort and sound (to my ears).
Glad you are "getting it". For the itch - I would try soaking them in some gentle detergent and warm water for a while, then rinsing them out to dry for awhile. That softened mine up a bit and well itchiness is not usually the way I experience them.
Mr.speakers alpha pads for $50.00 very comfortable.Quote:
I agree 100% (probably, haven't heard the vegans myself). But $80 bucks versus $10 bucks for the velours - no thanks. Not when I am already maybe $430 or so invested into my HE-400s, and the cable is falling apart and I probably need to fix that next! If anyone knows how to get a pair of compatible cables cheap, I would be all ears. Cheap means, like, $10 bucks. Or I suppose I'll have to try to make my own.
