Focker
The 400's ... also have a very high treble response
I"ve only had my pair for a couple weeks, but this is not something I've noticed.
Velour pads get rid of the 1k resonance that pleather pads have. Use EQ to mitigate the 12khz peak on the HE-400.
Masking energy that high up while keeping energy below in-tact requires very thin material, as to only reduce the super high frequency treble.
I've not tried or needed to do any of that, as EQ provides the simplest change with desirable results. Most of the energy around 12khz of the HE-400 is not a direct result of resonance, but just a tuning decision, so there's nothing that damping can do that EQ can't do just as well.
Is there a specific type of thin material that's proven to lessen only the 9-12k region?
Yeah, using EQ right now and have the velour pads. But I'm thinking there might be a way to deal with the peaks using the pleather pads (prefer its seal and comfort) and without EQ.
Is there a way to deal with the peaks by using sort of paddings like felt etc. inside the grille?
Well you're being a bit facetious but I'll indulge. Analogies are never perfect but provided someone doesn't attempt to nitpick them apart, they give a general overview of the comparison in a way some people may find easier to understand, others may need a different analogy.
There are dozens of factors in an amplifier and speaker set up that effect things like speed, distortion, loudness, etc. Even 2 amps, with the same rated power, may have very different speaker response on the same source material due to non audio things like the power supply etc. Electrical mechanical engineering is a very complex subject and we could be here all day outlining the finer points of it.
Agree with one thing you said above (leaving the power debate out): Both my planars seem to distort at lower volumes than my dynamic faves the HD-650. They both have very nice sound, but for times when I want full-bore rock I'll reach for the dynamic cans every time.
Where I find the LCD2.2 stands out (and to some degree the HE-400) is the level of dynamics and detail at lower volumes.
How high is the volume when you start to hear distortion? Like rock concert level? or higher? I rarely get even close to rock concert level, it gets painful, did enough damage to my ears going to many in my younger days, at this level I've never heard distortions with any of the Hifiman or Audeze headphones that I owned.
