Oh yeah haha. He added me to the list so I'm just in the waiting process. Just wanted to see if there were other ways besides jergpad and software stuff (for EQ) to help with the sibilance. Thanks for the tips though.
The jergpads have near enough cured it for me. Now, it's just the odd recording that has some treble harshness and it's miles more handleable even without EQ.
Does anyone have a Vali+Modi combo and if so how does that setup sound with the HE-400? I have a Vali coming but I really need to get a DAC also and the Modi seems like a logical choice. I've read where some say its to bright and if that's the case I don't want one then because the 400 is bright enough as it is. What are some other good DAC's in the under $200 price range that would be a good fit for the HE-400, also would like it to sound good with my HD600 as well.
I was looking for portable dacs a few weeks ago & I made this document. I ended getting the Stoner Acoustic UD110v2. Pretty happy with my purchase considering the price hope this is semi-helpful. cheers.
I have a pair of HE 400s with velour pads, and I enjoy listening to them a lot. One thing though is that I do hear some sibilance for female vocals and even for some male vocals. My Philips X1 doesn't have this sibilance. Are there any ways to reduce the sibilance on the He 400s? I am running it off a Dragonfly v1.2 and Project Ember with the stock tube. I don't have jergpads yet. I'm not sure how much difference it will make to change tubes, but I have a GE 6DJ8 tube arriving soon and was hoping to learn how much sound change different tubes can make. Besides tube changing though, are there other ways to possibly reduce sibilance? It is debatable as to whether or not changing cables (such as toxic cables) will change the sound much right?
Loving the sound of the HE400, the bass tightness and extension, the speed, the clear treble. It makes the music come ALIVE and with my EDM's the experience is orgasmic. One thing though, HOW the hell do you guys deal with the weight? Coming from a HD650, this thing is like a bowling ball resting on top of my head. I immediately felt the pressure on my cervical spine and neck muscles, it's a freakin work out! It's sad that this is really my main complaint, apart from the earpads being too big and kinda bulges out too much not covering the front of my face and the back of my head. I just don't want a whiplash from wearing this too long.
Weight doesnt bother me at all but the HE cans ARE WAY heavier than my HD-650's and MUCH less comfortable even with the velour pads and the HD-650 headband pad on the HE-400 or HE-500.
Weight is just fine for me. LCD2-type weight starts being an issue because I get a pressure point buildup on the top of my head. That might be a culprit of the headband more than anything else though.
The wide suspension strap will work wonders in terms of headband weight distribution, if it is implemented correctly (with the right amount of concavity and flex).
I too am looking for a shorter cable to replace HE400 stock cable...A reasonable price is most desirable. I would appreciate any input or advice based on your experience. Thank You
The soundstage is definitely larger than the HD650's, playing some competitive FPS on my desktop resulted in better audio positioning as well. Even though I think the HD650 has a more refined sound, I prefer the edgy HE400 sound. The bass is freakin REDONKULOUS. The build quality is better than I anticipated, even though it looks butt ugly the materials used are very good. I think the weight would be the #1 issue for me right now. I'm also not sure why it's rated so much lower than the HD650 on our website http://www.head-fi.org/products/hifiman-he-400
