Yes, I did say that w/o specifically calling out phono or CD - hardware EQ or not is the choice as hardware parametric is either very expensive, limited, or mostly made for use in studio land.
Pity, as Parametric >> Fixed EQ re: fine tuning FR adjustments. Even a 31 band fixed freq EQ can't lay a glove on a Parameteric with say 6 bands of fully selectable inputs. In part that is because you cannot adjust the Q of the slope. Headphones such as the HE-6 has several narrow peaks and valleys above 3k. A Lokius with settings at 2k, 6k, 16k is like using a sledge hammer when you just need a size 2 Phillips screwdriver. The 6.2k rise in the SE is dealt with, but that issue IMO is well less annoying than the rise centered at 3.2k. But if you use the 2k setting to deal with the big trough centered at 1.8k, that 3.2k area will be boosted, not cut.
Another way to deal with peaks not near a fixed EQ setting is the in-line filters designed and built by Solderdude. I can't use that because its for SE cables only, and my amp in SE doesn't get out of 3rd gear compared to what it does in balanced.
