HiFiMAN 602: Talk about your initial impressions and specs
post-7043134
Post #811 of 1,195
shigzeo
The Hiss King
Website
ohm-image.net
Gee, I'd hate to deprive you of your player, though a bird told me that someone has my ES7's! I'd love to provide a good reference for people looking for new earphones, of course!
post-7043470
Post #812 of 1,195
yooss
You do have some incredible intelligence capability! I'd love to have a bird like that. Is it trained in CIA?
Anyway keep in mind that I didn't send the RE262 yet. There is a high probability that you would have some more work a few weeks later.
Wow I was listening to Capsule-'Retro Memory' and I was really surprised to hear some loud and strange noise with your ES7.
Was it a driver failure?
Turned out to be the player problem. This player makes one of the most pathetic noise I have ever heard from an audio equipment when the battery state is critical. You should hear it yourself.
post-7043834
Post #813 of 1,195
Pisn4e
^ haha yeah it scared the crap out of me the first time i heard it.
post-7044883
Post #814 of 1,195
yooss
Yeah It is like somebody trying to drink milk with a straw but there is almost no milk left!
Btw I think the es7 is suffering from the same problem, much, much more bass than what I would hear from other sources. I really hope Fang will come out with a solution.
post-7045029
Post #815 of 1,195
david1978jp
Does anyone hear electric current noise when volume is below 2 ?  Does the noise go away after 200 hours ? I have it on 10 hours daily burn-in process for 3 days now. By the way, I will mainly use it with low impedance earphones.
post-7045043
Post #816 of 1,195
CSIR
http://www.head-fi.org/forum/thread/520941/hifiman-602-buzzing-after-charging
Is this what you experience.  What headphones do you use?
post-7045502
Post #817 of 1,195
asrphani
I think it doesn't support wma lossless.Every time I play a song encoded in wma lossless my unit simply becomes unresponsive.
post-7045528
Post #818 of 1,195
shigzeo
The Hiss King
Website
ohm-image.net
What other sources do you have? You know, it might just be that the Hifiman 602 doesn't roll off its bass with less than 80Ω headphones, something that very few players do. The ES7 is a bassy headphone - clear and loud, yes - but definitely bassy. So, any bit of proper resolution will bring their bass out. That, and a goodly bit of harmonic distortion in the signal will warm them up a lot.
So, what you are hearing could be many things, one of which is simply good resolution. If you've only used Cowon, old iPods, HTC phones, and the like before, then you are probably not used to the resolution. That isn't a problem, it's just that you've not heard it before. That said, I haven't heard the ES7 and the 602 yet... someone took the headphones before I could!
So I cannot verify anything.
post-7045532
Post #819 of 1,195
I didn't think anybody used WMA lossless....
post-7045597
Post #820 of 1,195
asrphani
Unfortunately I've a couple of albums encoded in WMA lossless.I've no issue if it is not supporting it but, may be it it could display "unsupported format" rather than just hanging.
post-7045699
Post #821 of 1,195
kostalex
You sound snob.
But you are right.
HM-602 is great.
post-7046027
Post #822 of 1,195
Anaxilus
[size=medium]
Probably not related but OMG is this thing susceptible to external interference.  If I use my Arrow w/ the bottom screws facing the 602 back the buzz and noise is terrible.  If I swap it to the other side the noise is gone.
[/size]
post-7046578
Post #823 of 1,195
Anaxilus
Loaded up 14 gigs of SACD on the internal.  Sounds superb!  Plugged into Data EXC port and Windows popped up the internal and external no prob.  No slow load times either.  One 100MB file took about 20-30 secs.  Undocked and updated perfectly.
post-7046679
Post #824 of 1,195
yooss
What can I say? I'm just happy when I hear the music. Bass, mids, treble, to tell the truth I don't actually care a lot now. I just like it.
I finally sold my 262, and I am looking for some sub $200 can. Any recommendations? I just messaged the seller of the Audio Technica A900TI who are selling it at $200(which is called the best trance can in the Korean forums--Shigzeo maybe you want to hear it sometime).
post-7046752
Post #825 of 1,195
Anaxilus
Alright.  Its finally happened.  Internal memory freeze.  What's the reset protocol for this thing?  Is it that ridiculously smaller than typical hole?
