SciOC
Ditto. Very poor EQ. Also the reason I sent mine back.Also if you use EQ the M5s has a poor implementation. Shanling are meant to be fixing this but I got fed up of waiting and sold mine on.
Glad I didn't buy a m5s!Ditto. Very poor EQ. Also the reason I sent mine back.
For those who have encountered popping/crackling/other noises when their R6 Pro was right next to their mobile phones, did this only happen when you had your IEMs connected to the balanced output?
I have had my R6 Pro for a couple of days now and not heard any noises, even when I stack the device on top of my iPhone. However, I have only been using the 3.5 output so far (waiting for a balanced cable with 4.4 connector to arrive). My IEMs are JH Audio Roxannes with stock JH Audio non balanced cable.
Thanks for the feedback re the mobile phone interference issues. I suppose I have to wait for the balanced cable before I know how bad it is (although I think I can safely assume this issue is a design flaw, and will exist with my device too).
On a separate subject, the R6 Pro has the "high-res" Bluetooth codecs etc (eg LDAC and aptx HD). Has anyone tried the sound through a bluetooth headset which support this hi-res bluetooth? (I assume is there is still some degradation in sound in hi-res bluetooth vs just a wired connection, but question is how discernible is that difference with say FLAC quality audio).
I just don't see how a firmware update could fix the underlying hardware issue....I don't have ANY interference on the 3.5mm.
My issue is only, when using the 4.4mm jack. I think its one part cable jack design, part hiby jack tolerances, as I have issues with some cables and not others. I have no issues with the same cables, using my DX200/amp8, wm1a, or Fiio X7II/am3b, which all have 4.4mm jacks. So its definitely a HIby issue on my end. Others have varying degrees of noise. Still waiting on a newer firmware update, I hope that fixes it.
Bummer that we have to be careful about what cables we use. It'll make buying cables a crapshoot.
Has anyone experimented with plastic spacers? Honestly with my ibasso ca02 adapter it looks like the plug doesn't quite go all the way in, but I have no problems.....
We won't know if it's just a few odd units, until more ship and others can detail their experiences.
Quite a few members do NOT have any issues
Mine does not have interference issues .using a Sony made 4.4 cable and have no issues at all. International edition.We won't know if it's just a few odd units, until more ship and others can detail their experiences.
True, and I am one who has had no interference or cable issues, but it makes me leery of buying new 4.4 cables rather than just continuing with my adapter....We won't know if it's just a few odd units, until more ship and others can detail their experiences.
Personally I have not encountered any interference or popping/hissing during my general use since I had mine. I did tried out 2 sets of popular wireless headphones in shop, the Bose QuietComfort 35 II & Sony WH-1000XM3, with R6 Pro's bluetooth connection and did experience short interval blank with the latter during playback.
I just tried with my iem (sf5pro) at 3.5mm jack while placing R6 Pro right next to my mobile phone (bluetooth connect to my smart watch, wifi on connected to my home wifi router). Playback is still clean. Then I stack my phone on top of R6 Pro, there I get slight interference noise on the left side of my iem. It is rather some short white noise than popping. Both these positions are not common in my daily use, I am not too worried about it. Hope you get your issue solved soon!
