SciOC
Try dropping the gain slider down to -6db or below and see if that helps in the EQ.....
That doesn't sound good. Which version do you have, intl, chinese or musictek? Campfire iems are extremely sensitive and very few daps, can handle that match, WITHOUT hissing.
Phew that's good to knowI got the hissing and popping to stop I think. Didn't realize how much force the 4.4mm jack required, so it may not of been in entirely which would explain the pop and static. I'm not hearing either anymore (hiss is not perceivable unless it's completely silent, but I've given up on 0 zero hiss from the andromedas). Sorry for the false alarm.
Edit: On a side note, the heft of this thing is pretty crazy.
Cowon L with Mass Kobo amp from Japan.Lol, what dap and amp is that?
whats the difference from international vs Chinese?only playstore?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
So yeah, the bad news is this: I thought I got the hissing and popping sorted out, but I didn't (It's really noticeable when songs are transitioning to the next--it sounds like a hiss popping in and out, like static that comes out from an old CRT TV on the static channel).
I tested this on multiple hi res albums just to be 100 percent sure this time (sometimes I think my brain plays tricks on me). I tested this using a few different balanced cables: two separate fiio 4.4mm mmcx connected headphones and a cheapo 2.5mm brainwavz cable converted into 4.4mm using the free caiiyin converter, and all three balanced cables have the same problem. I've lowered the db on the EQ slider to as low as I could get it to see if that would fix it like another member suggested to no luck.
When I switch to single ended 3.5mm litz cable that cable with my Andromeda, the pops, hiss, and static completely disappear. I wonder if the Andromedas are just hyper sensitive though because I also wasn't able to use my Andromedas using a Hiby R3 either, which has a low output impedance that is recommended with the Andromedas. Has anyone else had this problem using Andromedas in general? Like, I don't want to attribute this to the DAC just yet, but I also don't have any other IEMs within the same sensitivity range as the Andromedas. For all I know, the Andromedas just don't like playing nicely with a balanced setup.
This kinda sucks, because I really wanted to take advantage of using the 4.4mm jack. That a lowered output impedance (along with Android OS) were the main reasons I jumped at the chance to own this DAP, so I'm left just a little disappointed and confused at this point. Anyone else got any input with a similar scenario using the R6 Pro?
