Hiby R6 Pro - serious upgrade to popular DAP
May 1, 2020 at 12:07 PM Post #3,271 of 4,002
On Tidal after R6 Pro mqa firmware update, Mqa albums seems to randomly skip tracks.
And there is no way to get the player to read those tracks. It is determined certain tracks cannot be read.
May 2, 2020 at 5:48 AM Post #3,274 of 4,002
May 2, 2020 at 5:14 PM Post #3,276 of 4,002
My Tidal MQA works, but I can not get back to playing the music files on this DAP. HELP!!!!!!
My opening page has the 5 icons across the near bottom of the screen. The middle one is for HiBy Music. If I select that, I get a screen that says: An Entire New Infrastructure for USB DAC. Also has a graphic showing gears. It is frozen/static. Leads nowhere.
May 2, 2020 at 6:19 PM Post #3,277 of 4,002
Is there a way to get 12 hr AM/PM time to show on the Hiby lock screen instead of 24 hour format?
May 2, 2020 at 6:29 PM Post #3,278 of 4,002
Settings/System/Date & Time/Use 24-hour format
It’s an on/off slider
May 2, 2020 at 6:51 PM Post #3,279 of 4,002
Any change to Amazon Music HD operation?
(I gave up Tidal & Qobuz)
Thanks
May 2, 2020 at 7:53 PM Post #3,281 of 4,002
Thank you.
I have since migrated to Amazon Music on a Sony 507 DAP.
but still have the Hiby R6 Pro DAP and may keep the “ole brick”:gs1000smile: and I still have a W5 somewhere in a drawer.
But actually I am using none of these during this Covid lockdown - just using my Mackbook and over ear headphones at home these days. (With no commuting)
I use my Fiio Bluetooth neckband + iems while on the rowing machine. That’s about as portable as I get. But I listen to podcasts from my iPhone when doing that.
May 2, 2020 at 8:15 PM Post #3,282 of 4,002
I tried that setting and it changes the android lock screen time but not the lock screen that the hiby app uses during playback (It replaces the android lock screen and is an option in the hiby app settings). For some reason that stays in 24 hour time format no matter what. I can’t find a setting for that one for some reason.
May 2, 2020 at 8:52 PM Post #3,283 of 4,002
There’s a setting in Hiby Music to use Hiby music lock screen or system lock screen. Otherwise, I don’t see a way to change it either.
May 3, 2020 at 1:01 AM Post #3,284 of 4,002
Okay. That’s where I am at with it as well. No big deal though. Thanks for looking.
May 3, 2020 at 7:30 AM Post #3,285 of 4,002
I am serious. I can not get this DAP to even play the music I put in it. I can play music using Tidal that I installed, but not the music I installed.
