rlw6534
the original R6iii?
Maybe Hiby has made too many R6 variations to keep things straight...
the original R6iii?
and what is the build number of your poweramp app?Yes , original R6III
I love its sound a lot and would be very happy if Poweramp could work well with its hardware bittons!
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
The latest version available on Google Playand what is the build number of your poweramp app?
That can vary from user to user and device to device. To top it off we don't even have direct access to that at headquarters.The latest version available on Google Play
Version/Changelog build-976-bundle-play [976004-c2601e58] Full Version 64 bitCan you check the version number in settings->apps->Poweramp?
My i ask again if there is a solution for this?To confirm, i can not get a stable connection without hickups even though the phone is right next to the player
Is there anything wrong with the bluetooth module of my player maybe?
Don't have any such problems with other devices
Bluetooth DAC function is basically unusable![]()
Sorry for the late reply. Try emailing hello@hiby.com .To confirm, i can not get a stable connection without hickups even though the phone is right next to the player
Thanks a lot for your reply, i will write a mail.Sorry for the late reply. Try emailing hello@hiby.com .
How long since receiving the player was it when you first posted about this?
Hi there,@Joe Bloggs My Poweramp question is solved, I have found myself the way to fix buttons misbehavior, I apologize for taking your time
I have managed to find a right setting amongst thousands inside Poweramp that repairs a buttons issues. By default installation it's having this problem, I spend quite a some time to get to this.What was your solution?
Thanks for the reply. That sounds promising... How do I get to 'developer options'? Be gentle with me, I'm completely new to Android...I am not an R6III user but I wanted to write. Did Audiolab not work when connected to external power or did you try to give all the power from USB with R6 III? If it is connected to a power source other than USB, change the "Disable USB audio routing" setting in developer options and try it. If it is only powered via USB then use an adapter that allows for an additional USB power cable. And try to connect other android phones to Audiolab.
The speed at which files are accessed on the card may be related to the card's reading speed. Is your card fast enough? For example, does the speed make a difference when you try to read data from the card from your computer?
I am a very polite person, don't worry.Thanks for the reply. That sounds promising... How do I get to 'developer options'? Be gentle with me, I'm completely new to Android...
