I wonder Should we ask for replacement of our units or this is not critical defect for hiby?Yes! I see some 'triangles' under my screen as well!
HIBY R6 - DAP Dual DAC Balanced Out - Great Reviews and Over 500% Funded @ Indiegogo!
- Thread starter CactusPete23
- Tags
- hiby hiby r6 random bombs
My Micro SD card is stuck in the SD slot (just the card, not the tray). Does anyone know how I can get it out....
Dobrescu George
Reviewer: AudiophileHeaven
How did you do that?
Most GSM shops should be able to get it out for you.
I'd be careful not to break the pins inside.
I'm too embarrassed to say.. Actually, I couldn't get it to fit in the tray and stupidly put it in to see if maybe I could slide the tray in afterward... I know, pretty lame.
What is a GSM shop?
(I'm really new)
What is a GSM shop?
(I'm really new)
oliwek2
Why don't you buy antistatic tweezer(s) ?
This kind : https://www.amazon.com/Precision-An...-Jewelry-making-Laboratory/dp/B019SLLOMY?th=1
From China it costs peanuts : https://www.aliexpress.com/w/wholesale-antistatic-tweezer.html
(a GSM shop is a shop where they sell cellular phones/smartphones)
Thanks, just did that... So... I'm wondering on why the card (SanDisk Ultra microSDXC UDS-1) wouldn't comfortably fit in the tray and just slide in??
Dobrescu George
What is a GSM shop?
(I'm really new)
GSM shop is where you go to get a screen protector applied, or where you go to repair your smartphone, change display, etc.
Those are good, but you can still physically bend or break the pins inside if you're not careful, this is why I didn't suggest it.
Funny stuff that they are so afforable in there...
It fits in the tray pretty comfortably, like any other device I had. The margin of error is pretty smol, so maybe you need to fiddle a bit with it, but microSD cards should never go without their trays. The major thing there is that the tray doesn't need the microSD to sit in it, you just place it there, it should sit flush, then you carefully slide it in. It is not supposed to stick to the tray, this is how all smartphones work (?)
Okay.. thank you... For whatever reason I couldn't get the card to lay comfortably in the tray. I'll take it into a GSM shop and pray they can get it out...
androidjedi
still having issues after trying what's been advised with album art (hiby version 1.3.2) - not all album covers are showing in the album section and none are showing on my linked smartphone via hibylink -version on my smartphone is 3.0 international version
Will you have SD845 ver. in the future? I want something powerful like V30 but better audio. I'm willing to pay the premium. Thanks.
Johnnyfr03
Tried the album art fix. Fixed 80% of the artwork but as math can tell you still not perfect! I love my R6 but this is so annoying!
Vitaly2017
Hi folks I am very interested by hiby and been following this from beginning. Can some owners of hiby r6 confirm that it works well with spotify and tidal in offline mode? I also intend to use it as a dap only to get bit perfect out put via usb to my hdv 820/ hd800s. I need that bit perfect.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Yes, I have the triangle at the bottom but not the top. Doesn't affect touch screen operation, and not visible once artwork is displayed so not fussed. Bit more fussed about the wifi though. Not expecting blazing fast speeds, but do expect it to stay connected when everything else does on the network. Before Joe asks for a wifi analyser screen shot there isn't much point as when it is connected it's fine. It's just staying connected that's the issue.
I have a 400g sandisk in mine and OK.
Dobrescu George
I answreed this a few posts above, yes it should work just fine with Tidal offline files, just doesn't have DSP while doing that, so no EQ. Bit perfect in Tidal should work very fine.
Total: 8 (members: 0, guests: 8)
