Shady88
April. Check my message in previous pageJoe, any estimates when the R3 Pros will be back in stock anywhere? They seem to be sold out everywhere and I'd love to pick one up.
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
This is a Tidal API limitation not a player / technical limitation. It's entirely down to Tidal to make offline for non-android possible.So, is there any more information about this doing Tidal offline?
But it's possible on the R3?! Says so in this article: https://gearpatrol.com/2018/03/30/hiby-r3-hifi-player-tidal/This is a Tidal API limitation not a player / technical limitation. It's entirely down to Tidal to make offline for non-android possible.
Yeah, you're right!Looking at the R3 thread on here there's plenty of people saying they wish it had it ....
I really don't think it does
Any DAP using Android can (assuming it allows whitelisted or play store apps)
You can also offline from Tidal on a phone and use the R3 (pro) to LDAC the music to the amp so you're using the R3Pro to power headphones .... or use a USB cable from phone > dap and get MQA that way
Ldac is pretty decent on quality modeYeah, you're right!
USB from my phone does not work. Tried that with my E17. Is LDAC as good as wired on the R3? Or on anything?
We'd given out incorrect PR info on this back before the launch of this device (since we did not envision any barrier to the ability) before further communication with TIDAL revealed that it was contractually impossible. After that, we had trouble getting all the major news outlets to issue corrections to their articles, never mind the small ones copying the big ones.But it's possible on the R3?! Says so in this article: https://gearpatrol.com/2018/03/30/hiby-r3-hifi-player-tidal/
I've ordered another one of these. Basically just for the higher quality sound in a small package and the battery life.
Battery life on my ap80 is starting to wain, and the r3pro has a bigger sound stage which I like. Well see if I still have bt issues with the new firmware, but damn it's nice not to have to charge a device a lot.
The phone I don't mind as much with the wireless charging but a dap can be a bit of a pain if you're using it as your everyday dap.
If you don't mind me asking what Shop did you buy them from?
