gjohnst4
- Nov 20, 2010
So,
I have owned a pair of DT990/600 for about 4 weeks now and have run into interesting differences with balance.
Out of my main source ( lossless cd rip >>>> X-fi Platinum line out >>>> Fio E5 >>> DT990) The left channel is slightly louder than the right, but the left is more dynamic by far. If I adjust the balance through software, I usually keep left at about 92, Right at 100. This set up does not sound bad, but is quieter than I would like with the 600ohm resistance.
Out of my receiver, the imbalance is significant. The receiver is an Onkyo TX-SR607. I have to crank the right channel sound almost 75% to achieve balance.
And finally out of my Bravo tube amp using a Sylvania 6922 ( X-fi Platinum >>> Bravo >>>> 990) I used my software again and needed a 75/100 mixture to achieve balance and the 990's sound quality takes a significant hit, especially in the Right channel. The right is less dynamic, and slightly distorted.
I know there is going to be varying synergy between headphones and amplifiers. To test each set up, I have been cross referencing with my Grado 325is and they sound wonderful from each. The grado's sound best following the Bravo amp, very dynamic.
Does this sound like a blown driver? Or a cabling issue? The best sound Quality has been from the Fio E5 (surprised me!), and the 990's don't sound bad, just quieter than I would like after such a tiny solid state amp.
Thanks for any input.
