Originally Posted by dw6928 /img/forum/go_quote.gif
Carlosgp, you know you would hear from me.
Yep, I knew it
. I will try to comment further to the extent of my capabilities with the english language.
I am really confused by your analysis of the Microdac/Heed/701 combination. I find that the Heed smooths out exactly what you find objectionable and is both lucid and true when it comes to cymbal and higher registers.
Yes, this is why I decided to intervene as soon as I had an opinion more or less formed. This is not what my ears are hearing: cymbals sound somewhat strange to me. But not only cymbals. I find the plugging of the strings in a guitar spectacular and impactful, but a little metalic and not fully convincing. I enjoy this for a while (it has a lot of wow factor), but it bugs me at the same time. I usually end a little fatigued by this effect.
What kind of ICs are you using? That is really the only salient difference we both have.
I am using a Kimber Mini to RCA. But we are using a different pair of ears too
To my ears, the 701s favor the Heed more than any other amp I have thrown at it. I just borrowed a V3 amp (PinkFloyd modded) and it was not up to the task as is the Heed. The highs were well rounded but not expansive. Please spend a little more time with me on this so that I may understand your objections. You are the first I have encountered that hears this from the Heed/701
Probably this is a sensibility I have to certain kind of highs. Maybe other people with similar sensibility may found my comments useful. But I think is more related to the K701 itself than to the canamp. If you like the K701 from the beginning I suppose there may be no problem. In my case I am not even sure if I like the presentation of K701. I am still undecided
But maybe I exagerated a bit. I am still having mixed impressions about the K701 and this combo. Some days it sounds good enough, some days fine, some days very fatiguing. Maybe my brain has not made the "burn in", or maybe is my mood affecting my sensibility to high frequencies. With jazz quality recordings I usually have less problems or not at all, but with rock music the results are much worse, specially with drum kits. I can not see myself using these cans with rock music ever.
Another thing is that I am not from the "school of detailed sound" in hifi audio. I usually do not find natural this kind of equipment, and I think this may be the case with the K701 in the first place.
Carlosgp, have you considered a cable upgrade? Drew at Moonaudio does great things with 701s and I believe it would be the solution to your objections if it is within budget.
I am afraid this is not an option. The K701 are borrowed
. By the way, thanks to picodeloro for the loan.
