I understand that many people won't make any EQ with the Heddphone as it is already a great pleasure as it is. So sorry for them, that I publish this rather long post.
But, for those who wants to explorer some more details in the sound, as there are some margin in the 5.5/6Khz and a bit at 10khz, I will just put some of my non-professional measurements that I tried today with a MiniDSP Ears with and without EQ.
The setups I tried were those, all connected to my PC with REW and to the Heddphone with a 4.4mm to 2x XLR balanced ultra low capacitance cable :
1) SMSL M500 (USB DAC Input and 2 XLR output ) + Monolyth THX887 (2x XLR intput XLR4 to 4.4mm output)
2) MiniDSP HA-DSD (DAC 3.5mm output) + Monolyth THX887 (3.5mm unbalanced input to 4.4mm output)
3) FIIO M11 (USB DAC with 4.4mm output) + Monolyth THX887 (2 x XLR input to 4.4mm output)
4) FIIO M11 (USB DAC with 4.4mm output) + PA3S+4.4MM with 2W (Balanced 2.5mm input, 4.4mm Output to Heddphone)
So first .. for frequency response, I can't see any real difference, even if, unfortunately, under 40hz, in my office there are plenty of low frequencies with a high noise floor (walking people, lift, air conditioner, wind, etc). My measurements are made in a placard and not a well close cabinet with a real noise protection from outside.
So, actually I can never get twice measurements between 10hz and 40hz even with the same config in less than 1-minute time difference.
But, I would clim that every config looks similar (and THD not really different too)
Then I could test some PEQ config based on the autoEQ parameters made by Oratory1990 and some of my own parameters.
For this, I use a Minidsp HA-DSP, which make easy to input PAQ data and measure them quite instantly.
Sowe we can see the 3 frequency response which are rather different and confirmed by my own ears
.. of course my favourite sound is under NW666 PEQ
THD with no EQ
THD with AutoEQ from Oratory1990
And EQ made basically with the Oratory1990 parameters and adapted to my own taste
But what I can't show with those measurements is the difference in real life between M500 as DAC and Monolyth THX 887 as amp with 6W , compared to an amp like the PA3S+ with 2W => lower frequencies are definitely better to listen with more watts available (I suspect peak power is a big factor and can be more important than the sustain power itself for low frequencies).
As my freedom to listen to good music anywhere I want in my own home is very important for me => I ordered and I am waiting for one more new model of portable amp with the CETRANCE M8 V2. It seems to be able to produce till 20V in peaks and probably 1.4W (sustain at 32 Ohms).
I think my actual PA3S+4.4mm is a cheap amp manufactured in China and probably far from the 2W as announced by the manufacturer and it is probably very far beyond what the Heddphone needs as peak power (which can be produced easily with the THX 887).
So this was my non-pro contribution, for people enjoying adapting a bit their headphones sounds to their own taste... of course I wouldn't claim it to be essential in the Heddphone situation, but i think it's worth to explore as they are many tools available PC or DAP.
