Hi everyone, I went to a headphone store today and tried a bunch of different headphones, made some notes and comparisons below:
Equipment used: Simaudio Moon HPA 430 and Tidal
Final Audio D8000 – Natural timbre and tone, fantastic powerful bass (think TH-900 level), non-fatiguing treble, dynamic/impactful/fast, fairly forgiving to poor recordings, makes you want to head-bang, a convincing upgrade to the Fostex TH600/900 (my benchmark headphones for metal listening), pads are ok but not amazing, resolution/detail could be better for the price, over-priced
Final Audio D8000 Pro – Better clarity/resolution/detail than D8000 and better pads, , but weaker and less satisfying bass, combine the bass of the D8000 with everything else from the Pro and that would be damn near perfect for metal listening! Over-priced as well
Sennheiser HD800S – great overall sound, very wide-soundstage, too similar to the Focal Clear which I already own, well-priced, best headphone on the market up to 2k along with the Focal Clear
Sony MDR-Z1R – Warm and lush sound but still detailed, decent bass, non-fatiguing except for a treble spike, comfortable, great closed-back, lacks in technical abilities compared to the others, should be cheaper
Grado G1000e – Excellent top-tier clarity, detail and resolution, a bit too bright and sibilant though and will be fatiguing to a lot of people, beautiful, sweet, and full mid-range, probably the best overall mid-range of all the headphones I tried, I'd like more bass quantity and dynamics/slam though, the earpads are a bad joke, I mean truly awful, why do you use the cheapest foam possible Grado?
Hifiman HE-6SE – Superb mid-bass and overall bass detail/texture, excellent clarity, detail, and resolution, best dynamics/slam in the Hifiman line, a little bright and probably fatiguing over a long listening session, a beast to drive
Hifiman Arya – The BEST imaging that I have EVER heard on any headphone, superb overall sound, great value, a little more bass quantity, dynamics and slam and these would probably be my favourite! If you have been eyeing-up the Arya then my only question would be "Why haven't you bought it yet!?"
Hifiman HE1000se - great overall tone and balance. The resolution, clarity, and detail is top-tier, lacking in slam/impact/dynamic range, a bit too flat and lacking the ‘balls’ for metal, should be good for most other genres I would imagine though,
Hifiman Susvara – Get the Arya or HE6 instead unless you are a millionaire and MUST have it, even then I would buy it second-hand, it's a mix between the HE-1000SE and HE6-SE sound wise, calling it over-priced would be an immense understatement, a beast to drive
Audeze LCD-3 – Better clarity, detail, and resolution than the D8000, but has an off-sounding mid-range, good planar bass, good speed and impact, dynamics/impact not as good as D8000 and others
Audeze LCD-4 – A more resolving/detailed version of the LCD-3 sound with the same mid-range tonality issues, could be end-game, I’d like a little more bass quantity and slam but that’s more of a nit-pick, would get heavy and uncomfortable after a few hours, EXTREMELY over-priced
Fostex TH-909 – A more balanced version of the TH-900 with less treble and bass but maintaining a similar tone and timbre, excellent overall sound, not sure if it’s worth it if you already own a TH-900 though, great for all genres, especially vocals
Focal Radiance – gorgeous design aesthetic, sound quality wise it sits somewhere between the Elegia and Clear, not worth the price considering they are only slightly cheaper than the Clear and the Clear is significantly better sounding IMO (unless you MUST have closed-back)
TL;DR:
Overall Preference based on sound quality:
D8000 > D8000 Pro* > HE-6SE = Arya > TH-909 > Susvara > LCD-4** > LCD-3 > HE1000SE > HD800S > G1000e > Radiance > MDR-Z1R
*D8000 Pro is the best sounding overall, but the increased bass on the D8000 is incredible!
** Would probably be the best overall once they fix the f**ked mid-range!
Best bass: D8000
Best mid-range: G1000e and Arya
Best Treble: D8000 Pro and Arya
Best overall sound: D8000 Pro, second Hifiman Arya and third LCD4 (except for the wonky mid-range)
Best value overall: Hifiman Arya
Most comfortable: HD800s
Best aesthetics: Focal Radiance
Hope this was of some value to you guys!
