- Mar 30, 2012
Lol! That looked like the handiwork of a dog or cat.
hehe, I wonder how would a dog sound on a synth in a piece of metal
He loves jumping on the computer desk, this time he got a snack and replied to a post I had no intention of replying too lol.
This should help you expand the soundstage a bit:
http://www.head-fi.org/t/619447/hifiman-regrilling-mod
There is a bass mod in the OP of this thread which might help:
http://www.head-fi.org/t/738912/he-560-enhancement-mod-v1-5
A pad swap to the FocusPad-A would bring down the 2khz-4khz region a touch, which can make the headphone feel more bassy and more spacious - you're brain pulls a lot of location data from this frequency range, hence why it is often referred to as "presence."
A swap to the Audeze vegan pads (cheapest on B&H photo, I believe) splits the difference on the mids and gives you even more soundstage via physical space from the ear.
Otherwise, amp and cable swaps are always a great option... albeit a more expensive one. The X7 isn't exactly a bass monster. There is also EQ on the X7 via the app.
What is the physical difference between the stock focus pads on 400i and the focus A pads?
You guys are awesome!
Actually, HIFIMAN came through for me! They canceled my VelPad order in time, and I was able to order the Focus A pads, from their eBay store (no shipping). I think it will ship USPS First Class out of Illinois, so I should get it in a few days in NJ.
I'm leary of permanent mods at this point, because I'm still going through the exploratory headphone phase. I used to wonder why people modded headphones, but I totally get it now, and I'm totally curious how far I could take this headphone if I wanted to mod the heck out of it.
With that said, I expect to hold onto the HE-400i because it's soo good with metal, and every other type of music I throw at it.
I'm "auditioning" it now to get a handle on its sound with the stock pads, so I can better appreciate the affect of the Focus A pads.
I'll be sure to report back when I get them.
Most of those mods are reversible. I've swapped the grills on and off so many times. Just be careful with the plastic retaining ring (it's a little on the thin side).
Yes, I almost learned that the hard way last night when I decided to pull the stock pads off, without understanding how much engineering went into them. . I was expecting its locking mechanism to be a bit simpler. I love the AKG pads, and how easy it is to screw them on and off.
I know HIFIMAN puts a lot of thought into how they design these things, especially the newer ones.
Question: Do you need these rings to swap in the Alpha Dog pads? I know those are pricy, but people rave about them. Since these rings are glued now, it makes pad-swapping with non-HFM pads very difficult.
I wouldn't put alpha pads on an open can, personally.
Yeah, you would need the rings, or you could adhere with double stick tape... Which will sound slightly better, but make a bit of a mess.
Sure. The FocusPad has perforated plastic on the underside of the pad, whereas the FocusPad-A is just a regular cotton weave. The perforated underside is the main contributor to the boosted 2-4khz region.
Aside from that, the FocusPad has a 6cm opening vs. the FocusPad-A's 5.5cm opening.
Is it just the 2-4khz region that changes with them?
It's the most noticeable change. Actually, just rechecked measurements, and the boost is really closer to 3khz-5khz. As for other changes, the Focus-A also has slightly less treble around 9-10khz, but a little more air up around 16khz... in practice, I've found these changes to be less noticeable. Essentially, the FP has a little more edge and treble emphasis, while the FPA has a little more body to it. Preference is subjective.
If you're interested in comparing measurements, Jerg tested both pads and posted results in the OP of the HE560 thread (fittingly, under the "measurements" subhead). http://www.head-fi.org/t/711824/hifiman-he-560-impressions-discussion-thread
