MacDEF
Headphone Hussy (will wear anything if it sounds good)
- Jun 26, 2001
The purpose of this thread is to gather specific, objective, information on headphones amps for an "amp guide." The idea is to gather as much info as possible on as many amps as possible (both current and out-of-production models).
As discussed in another thread, the guide will not include information on sound or quality -- for that info, people will have to use the forums and other sources of subjective info. The purpose of this guide will be to provide a reference to specs/features/etc.
This thread will serve as a place to submit information on various amps. If you have information on a particular amp, please submit it here.
Information needed (please submit in this format):
Picture of amp (both a full-size image and a 70x70 pixel image)
Amp manufacturer
Amp name/model
In production? (yes/no)
List price (final list price if no longer in production)
Current "street" price (used only if no longer in production)
Type of amp (solid state/tube/hybrid)
Stock tubes (only if tubed)
Crossfeed? (yes/no, how many levels)
Other processors? (yes/no, type, details)
Portable? (yes/no)
Power supply (batteries/AC)
Detachable power cord? (only if AC, yes/no)
Number of headphone jacks
Jack output impedance (per jack, if more than one)
Jack output (per jack, if more than one -- include @ #Ohms)
Jack type (mini, 1/4", per jack if more than one)
Inputs (line, etc., how many)
Other outputs (line, pre-amp, speaker, etc., how many)
Speaker output rating (only if speaker out -- include @ #Ohms)
Possible upgrades/upgrade path (tubes, power supply, electronics, etc.)
Housing material (plastic, steel, aluminum, etc.)
Size (dimensions)
Weight
It's OK to post partial information if you don't have everything; hopefully someone else will be able to fill in the missing info. Also, if you post pictures, we'll download them from your post and archive them for use in the guide.
P.S. If there is an obvious information category that I left out, please post that, as well. However, please direct commentary and discussion to another thread, as we will be deleting followups periodically to keep the thread to a minimum.
Amp manufacturer
Amp name/model
Portable? (yes/no)
Size (dimensions)
Weight
