pauldgroot
- Oct 16, 2013
Bill, I have tried exactly the same liner as your black one and it didn't do much. I'll measure them again for you to see.
Ah, okay. No wonder I like it more than the one on the left.
The one on the left sounds like it boosts treble a bit too much, and attenuates everything else by a lot. The one on the right really does exactly what you described would happen: no sibilance, more bass.
So glad to know I'm on the right page now.
Now, you have found the truth - as much as I appreciate jerg for his modding attempts, once you get more into this stuff, you'll find out that the only way to get the sound you want is to mod the headphone yourself. HE-500 are a great example - the only match between jerg's and mine HE-500 modding procedures are the jerg pads (which are lovely, jerg, truly!). I spent months trying out everything possible and found quite a few better things to do with the headphone to my ears than those mentioned in jerg's guide - and I would expect you to come to the same conclusion, as already being the case obviously with the shelf liner. Dig deeper if you really wish to get the best out of your HE-560.
I don't blame jerg at all - he has no chance of being objective or finding the best way in an absolute sense how to modify something. I became suspicious after finding out that bass of HE-500 was even more bloated + muddy than stock with his pad adhesion and vent mods - this made me dig deeper... On the other hand, in the end, I realised that extreme subbass is most probably something he loves while I find too much subbass to cause muddiness in the sound of a headphone. My personal view corresponds with the next image:
That's one of the reasons why I don't like pads that seals too much...
Here are measurements with the square liner Bill. It might change something from 11KHz and up but that could just as well be a measuring artifact.
Anyone tried these mods on the HE-400i yet?
I might consider it but how great is the manufacturing variance between one pair to the next? The mods performed on one headphone might not reflect the same changes on another headphone of the same make. I'm also aware while Hifiman makes high quality products, they're not exactly the biggest players in quality control.
Might be placebo but the pair I'm currently using sounds different than the pair I returned a month ago. It's not as sparkly and it seems to be darker.
And for reference, my serials are 411XXXX while the previous ones were 407XXXX so there is a rather large gap between the two.
Edit: Also I've listened to both pairs with and without the grills. I could not hear an audible difference.
Performed all the mods on my friend's fresh pair of HE-400i and they sound great. I wasn't sure if the HE-400i would benefit from the shelf-liner backwave dampening mod too, but I definitely think it helped. To my ears, it makes the upper mid-range and treble sound cleaner and more realistic. Along with the grill mod, it makes the HE-400i sound more airy, open, and detailed than in its stock form. The openness is a big deal for me, since the stock HE-400i just sounded really closed to my ears (coming from the HE-560).
Highly recommended for all HE-400i owners!
It's the same shelf liner that I've used and linked in the guide, this is just the white foam variety.
Have you tried this type of liner, Jerg?
I think I like the sound from this one better the square ones.
I believe it is different from the one on the first page. The white one has those 2 size holes but the black one is just 1 big size hole (beaded). What s the name of the white one? Like what types of liner those are?
