I've recently made an amp discovery I would like to share. I have been looking for a speaker amp to drive my Paradox headphones, having heard how they sound out of the speaker taps of my Musical Fidelity A1 amp. Having been into audio since the mid 1970s, and having owned and listened to a wide range of very excellent gear, some of it considered reference level, I have a pretty good idea about what constitutes really good sound. But, I admit I am relatively new to the headphone end of things. We are now getting into the realm of speaker amps, and I believe that it's not just a matter of more power, but also the fidelity of said amp. That is likely why people are using Don Garber SE amps, Nelson Pass First Watt amps, and others costing multi thousands of dollars. I need to go the 'economical' route.
In doing a lot of web research, I came upon an amp by TBI called the Millenia MG3. Rated at 30 watts/channel on ac, and 10 watts/channel on batteries, it seemed power wise to be a good choice. There have been glowing reviews which compared the amp to some pretty esoteric gear. The TBI sells for $500 (with a 30 day trial period). Several weeks ago I took the plunge. Jan - the designer - worked with me tirelessly to help get the amp to work properly with my headphones. What needed to be addressed first is the fact that the headphones are single ended and the amps' negative grounds are not shared. Also, there was gain background hiss. He suggested some resistors to use, and described to me how to arrange them ahead of the headphones. Things were promising. Then he came up with what I call his magic box, with some resistors that not only address the above issues, but if I understand it correctly, allow the amp to see a more appropriate impedance match for the amp. End result is astonishing sound quality.
Jan went above and beyond to help me out. I am very grateful to him for that. But with the end result being the level of sound quality I am getting over my Paradox headphones (which continue to prove to be astonishing in their own right), I wanted to put out the word in case any others were interested to check it out.
Here are some links that are relevant to the Millenia. There are others. It also received the Positive Feedback Award last year.
http://www.positive-feedback.com/Issue62/millenia.htm
http://www.positive-feedback.com/Issue64/awards.htm
http://www.audiocircle.com/index.php?topic=108242.0
