steppenout
Double post here, but I wanted to welcome Slava. I'm a long time lurker too. These people around here are just great at helping us spend money!
Just received my Emotiva today. Great looking little amp and I was really surprised by its quality build and weight. Now all I need to do is actually make a decision on which headphones to get. I'm really torn between the HE-500, HE-5LE and the LCD-2. I would love to audition all three of them but it just isn't possible. For those of you that have heard all 3, which one would tame bright recordings the best? I'm just getting so sensitive to sibilance or harsh treble. My main listening preference is classic rock and I really like a fairly neutral sound. I also really like female vocalists so an accurate sound for those vocals is important to me. Oh, and I currently have the HD-650's which I truly love, but planars are the next obvious step. Looking for suggestions.
Hello folks,
Long time lurker here. I just bought my he-500. Feels good to finally jump on the wagon after almost three months of researching. I'm a newbie in high end headphones so please excuse my newbie questions.
Zoom25 mentioned that it might be risky to use single ended directly from speaker amps. Why is that? Can I use the single ended input terminal to connect my computer or DAP?
For the guys who own both O2 and Emotiva, which one do you prefer using with he-500?
Thanks,
dont forget the matrix mstage also! on gain 10db is capable to drive it perfectly in this pricerange...
Heya,
A lot of solid state amps can provide close to 1 watt at 38ohms for something like the HE-500 to be considered technically fully driven, according to Dr. Fang. However, the whole point of all this is to look at alternative amplifiers than the typical headphone amps that are constantly floating around here to find something more fun and atypical for use with planar magnetics, and other headphones in general, that can tolerate higher potential outputs from amplifiers that are much more powerful and robust, like a speaker amp.
If all one is needing is the technical power output to drive the HE-500, the $99 Magni from Schiit is half the price of the Matrix, and cheaper than an O2, and outputs 1 watt at low impedance.
That said, I can't help but suggest, if you're getting into a flagship level ortho, maybe consider looking into more creative ways to drive them. I for one definitely feel and hear the difference from a different amplifier and much prefer the speaker amp route for example, over normal headphone amps. In other words, don't sell yourself short, if you're using a flagship, you're not what one would call terribly budget conscious.
Very best,
The LCD-s of course. However, that little amp you have there is pretty aggressive and with lots of gain. You wont get to much play on the volume knob with the LCDs, but I guess you can make it work for you and find your sweet spot..
Don't know about HE-5LE. Go for either LCD-2 or HE-500 with pleather pads. Won't run into any treble fatigue issues with either combo. The velours can be fatiguing though.
Actually, if using a speaker amp like the miniX the 5LEs will respond better to all the power and current the miniX has to offer. All three are great, by the way..
Haha...you guys are a lot of help! So basically what you're saying is just buy all 3. Oh, and I can't forget the LCD-3.
Back to square one...
Seriously though, thanks for the suggestions and impressions. It's this type of information that I come here for.
Just pulled the trigger on some He-500's and I just happen to have a spare Mini-x, so I will be giving the combo a go. I believe from reading here the Mini-X is common ground, so no issues with wiring taps to a female 1/4th inch adapter correct? I mean if I have to build a 4 pin xlr cable I will, but it seems like a quick adapter for the stock cable would get the job done just fine. Has anyone tried a tube pre before the mini-x? I happen to have a HllY mkIII I'm gutting and actually putting quality caps into so it might be interesting to place it before the mini-x in my chain to give the cans a little more warmth, Thoughts? Either way extremely excited as this is my fist Ortho, and my first $$$ HP, I'm currently running a single piece mahog cup Magnum v4.
Should look like this.
Foobar2k to Essence ST to Hlly MKIII to Mini-X to HE500.
