HE-500, LCD2, D5000, DT770, SR80, on a speaker amp (Emotiva mini-X A-100) Project
Dec 8, 2013 at 5:19 PM Post #2,566 of 3,819
Thanks for the help. Looks like for this amp, I should go with a 2 ohm for Resistor 3, and 6 ohms for Resistor 2. This reaches the effective speaker load of 7.9 ohms which is nearly 8 ohms.
This creates an attenuation of -12.37 dB, which I think should be sufficient.
Can this even be done on a single cable or would you need some type of enclosure?
If you are careful with the connections, sure you can do it in the cable.  Just make sure everything is insulated with heatshrink so you don't end up with a direct short.  Also, upsize the resistor power dissipation rating, since everything would be insulated and won't have the chance to dissipate heat as if it were in free air.
Dec 8, 2013 at 5:29 PM Post #2,567 of 3,819
Eh, I was thinking of having someone build the cable. I would love to learn how to use an external resistor on the amp, but having never done so, I wouldn't know where to start, what to buy, and how to attach it to the speaker terminals on my amp. And I have a myriad of floating questions like: Would I be able to use banana terminated plugs on an external resistor? How would I check the values from an external resistor? Etc.
Would be great if there was a guide to all this, but it looks like it's just dispersed throughout several threads on this forum.
Dec 8, 2013 at 5:33 PM Post #2,568 of 3,819
Proof
 The pics are pretty bad, though
Dec 8, 2013 at 5:42 PM Post #2,570 of 3,819
Yes, a nice succinct guide would be nice.  The closest thing that exists, that I'm aware of it the "Speaker Amps for Headphones" thread.  Unfortunately, it does take a while to dig through all the info there.
If you mentioned it, I must have missed it, or just don't recall... What amp are you using? The Mini-X?
Dec 8, 2013 at 6:00 PM Post #2,573 of 3,819
   Quite bad, a good part of the diagram circle in shaped also melted
I'm not really sure whether it is the x-can as pre-amp doing weird stuff or if it was a short. Just know i connected right and left positives to the same channel, the negatives as well. Can't quite figure out what that'd do so late at night, lol. The emo did go into protection mode.
It doesn't appear to have melted from sight. Well, it has melted around the conductors in the alu film I suppose..
Dec 8, 2013 at 6:12 PM Post #2,574 of 3,819
davidsh,
it saddens me to read about your bad experience :frowning2:
I don't quite understand what when wrong for you, so here's a dumb question:
Did you use your Musical Fidelity as a pre-amp and thus not feed your amp with a line-out signal?
I only ask because I once made that mistake with a speaker system - fortunately my speakers didn't blow...
Dec 8, 2013 at 6:18 PM Post #2,575 of 3,819
Pre-out, not line-out. Will check whether the pre-out works properly tomorrow.
Dec 8, 2013 at 6:23 PM Post #2,576 of 3,819
I'm planning on using an old home theater amp I have which sounds great: Yamaha RX-V1200 (specs here).
Dec 8, 2013 at 7:02 PM Post #2,577 of 3,819
Did the driver of the channel that had both positives blow?
Dec 8, 2013 at 7:04 PM Post #2,578 of 3,819
If I were you, I'd get a balanced cable for the HE-500 if you don't already have one, and a XLR to banana adapter (Blue Jeans Cable is a good source) and just try it.  If the Yamaha has a low noise floor, and you've got enough volume knob to play with, you won't need resistors :)
Dec 8, 2013 at 7:12 PM Post #2,579 of 3,819
 If you look at the shiny part of the diagram around the hole you can see it is like a circle. Not the dull part.  If the protection mode did not react quickly enough the fuses will blow in the amp. Mine came with two spare fuses. Emotiva built the amps to last.
Dec 9, 2013 at 12:13 AM Post #2,580 of 3,819
Never got that upa-2. You know what happens when you accidentally short a 125 watt power amp with he-500? It blows. Well, not the amp, but the phone does.. Just don't hope my x-can has taken damage as well. There's literally blown a hole in one of the diaphragms. Cannot figure out whether my x-can works properly either. Let's see how good Hifiman warranty really is :S
I've done this. Didn't short out the amp but put too large a signal to the amp and blew a hole in a driver. It cost $130 to replace. Most of that, shipping.
