hemipowered007
They've been consistent at 169. If they were to go down any further I'd be forced to buy them. That's why I asked...
Originally Posted by fluidz /img/forum/go_quote.gif
Question, does anybody find the sibilance of He-500's to be a bit fatiguing at times? I've resorted to using spitfish to tame some tracks as my ears simply can't handle Vocal Tzzz sounds. I wonder if it's my Mf M1 Dac, as there is a marginable difference in sibilance between optical and usb output, optical smoothens the sibilance but i loose the sparkle of Usb.
Sibilance heard mostly in the 7.5KHz - 11kHz range and makes my shoulders shudder. Using Spitfish helps but I prefer not to use vst's to correct the sound and it's not a perfect solution as even with minimal effect applied cymbals can loose their reverb.
The HE-500 can fatigue me, though I don't find it sibilant.
Regarding the He-500 and Mini X. If you can't hear the noise floor, cup your hands over the outer part of each cup on your headphones, you'll soon pick up white noise.
I've owned two Mini X's, same with both. Computer fans on and all, can hardly hear it, not a big problem so don't let it bother you like it did with me with at first. I even returned my Mini X thinking mine was faulty, having asked around and most people at this forum saying they can't hear anything yet I soon bought another which I found has a low noise floor (same strength).
Being Mini X'less, I missed its awesome presentation, sheer power (you certainly feel it) and simply not being able to pair the he-500's with another amp for anywhere near its price.
Pretty sure MalVeaux was pairing his mini x with a tube dac right back at the start. Could try that if you want a slightly warmer sound.
Heya,
I used a tube pre-amp and now just use a tube dac which utilizes a tube based pre-amp output stage that delivers the line level signal to the Emotiva. It adds warmth and it's very smooth and soothing. Not a treble monster at all. But not dull either.
Very best,
Heya,
Very best,
How would the emotiva fair with low impedance headphones. I am auditioning the jvc dx700 and am finding it to my liking so much that I am dissuaded from getting another planar. Some report the 7520 to sound good with it. I would be interested in impressions of the combination even though the dx700 is making me sell the 7520.
It may sound funny that I am asking with all three here but I currently don't have the emotiva set up to test it as I sold my lcd2.2 with the speaker taps.
If it won't fair too well I will probably get another ortho to pair with it like a mad dog or an he400. I have already tried a modded t50, lcd2.2, and hd650 so I know this beast has to stay.
