majkel
- Jun 1, 2007
Beyerdynamic T1 because they are the best amongst the four. Denon AH-D7000 as the second choice. Maybe their bass is bigger than Beyer's but not of equal quality and extension. The HD800 have better bass as well. With the Meier Audio amp you have this advantage to switch the output impedance to 120 ohms which makes the T1 sound significantly better with solid state amps, especially those of "zero" output impedance.
