majkel
- Jun 1, 2007
I'm sure he meant 300 ohm.
One has 300 ohm and the other has 300 ohm. That gives 600 ohm in total, so he was correct.
From what I've read:
HD650: More impact in the low end. Slightly warmer midrange and less soundtage.
HD600: Wider soundstage, slightly more treble emphasis with less bass.
It's been argued before that soundstage perception and bass response are closely inter related.
HD600: less bass, less erratic treble response, flatter response.
HD650: slightly less harmonic distortion.
Everything else is the same.
Erratic treble response, eh? That's a new one.
I'm no expert so stand ready to be shot down on this but the differences between those two dips should be barely audible, although the 600s peak at 3-4k would definitely register, as would the across the board volume increase in the lower frequencies the HD650 displays. (And it certainly does).
