Nitrile
- Apr 29, 2006
It seems that the drivers default to 48K Hz in the playback settings for Mimby?
Anyone else have this problem?
So mimby SQ is superior then:
1) Mojo
2)m9xx
3)V dac 11
What did i miss?
I like the Mimby a lot if you see my earlier impression of it. However, I don't consider Mimby SQ to be superior to mojo. Imho, Mojo has more resolution and detail than the Mimby. In fact, there are days when I thought that the mojo resolution and details are just a notch behind Yggy. The mojo is musical and delightful to listen in its own way. if the Mimby is your first multibit dac, then you could be enjoying the multibit SQ much that you think the Mimby trashes the Mojo. If you have the chance to listen to Mimby, Mojo and Yggy side by side, you will understand what I mean. The Mojo is a gem just like the Mimby and both punch above their weight and price range. I am not the only Yggy fan who thinks highly of the Mojo, read Torq's impression of many DACs in the thread "Life after Yggy"
http://www.head-fi.org/t/804153/life-after-yggdrasil
Just my views.
Oh, come on guys! You ask this in the context on $10,000 and up DACs?? What are you thinking?? For the record, the margins are less than 2% different. If you want a better performing, upgradable unit, get a Bimby. If you want a multibit contender with cheaper parts and a way cheaper power supply, get a Mimby. It's assertions like this that make me wonder why I bust ass to make multibit affordable.
So I knew that it was going to sound better than my Dragonfly 1.2 that I bought used. I just wasn't expecting it to blow it completely out of the water. It's like the music came alive for the first time! Way more natural sounding, better detail, better everything. I have it connected to my O2 right now and I wonder how much better it is going to sound with my project polaris which will arrive soon.
Those are adventurous can slap on an alternative power supply. It's on another level on SQ. Darker noise floor.
I have tested 48 hrs, soundstage open up wider. Highs are smoother as ever.Runs cooler then supplied wallwart
Ok schiit you caught me Doesn't matter, im willing to forfeit my warranty if indeed any fault in the future has to do with it.
Such a splendid dac deserved a matching PS.
Regarding samples rates, it says on the website: "Modi 2 Multibit: 16/44.1 to 24/192 via USB. 16/44.1 to 24/192 via Toslink* and Coax, with 24/176 and 24/192 being NOS (non-oversampled)"
The non-oversampled part only applies to 24/176 and 24/192 over Toslink and Coax right? Doesn't apply to 24/176 and 24/192 over USB?
Stupid question here regarding power for the Mimby.
Instead of swapping power supplies, would using a power conditioner net you positive results as well?
I know this is highly debatable, but I figured I would ask anyway.
The original wallwart was plug into my balanced digital power supply. I did not know of improvement until i replaced it with the new AC 16VAC PS.
Thanks for the input. That was exactly the type of feedback I was looking for!
