Recognizing it is really new so the answer maybe no, has anyone tried any other mods out with the Modi Multibit yet? It was thinking that if it is a lot like the Bimby but with less expensive parts to keep the cost down, maybe modding it by upgrading a few signal caps or something like that would close the gap further.
... It was thinking that if it is a lot like the Bimby but with less expensive parts to keep the cost down, maybe modding it by upgrading a few signal caps or something like that would close the gap further.
I don't think Modi multi necessarily has cheaper parts, just smaller ones, if you look at the Bimby board you won't see any large "audiophile" film caps either.
I doubt there's room inside the case for "upgraded parts", I would suggest you leave well alone unless you think you can do better than Schiit.
The quality (or lack thereof) of the mastering of a recording is responsible for around 99% of its overall SQ.
I'll take a well mastered 44.1/16 recording that preserves the recording's original dynamic range (which are unfortunately few and far between in popular music) any day of the week over any ultra-hi-res recording that has been poorly mastered.
It can play DVD-A, it's just a high resolution LPCM, which can be fed to any Schiit DAC, either D/S or MB as long as it's native 2 channel or downmixed to stereo from 5.1.
DSD is a whole different story. Nothing to do with the bits.
I tried the Yggdrasil with my Linn universal player and it would not play dvda only sacd and only response I got from schiit is dvda is recorded in 24bit format similar to DSD from Sony.
When you are playing through the Linn. You are outputting 5 channels. Set the Linn to downmix to 2 channel or choose the stereo only tracks from the disc.
It's an optical out didn't see any option, plays as two channel into my naim or chord DAC, I decided against the schiit because it didn't support a quarter of my music, DSD.
I thought finding the best tube was a great upgrade for my Vali2 & Modi 2 Uber stack was the ultimate, but The Modi Multibit is really an eyeopener. Just like my Super Schiit Stack, I have started to hear stuff in my music I have not heard before COOL!!!!!
Yeah Sony released about 10,000 titles now and I have utopia two channel speakers with Dave DAC and naim preamp with separate biamping per speaker(Two amps to each speaker). DSD sounds much better with this type of set up, remastered cd quality has noticably less separation. Before DSD I had a bunch of dvda and sacd which most are now stored in drive, dvda are stored to 24 bit for full file size.
So as this is AC and not DC if I'm getting it right, this unit cannot be run off battery isolation for coffee shops etc or LPS units at home ? I WOULD be happy as a pig in Schitt if this thing is transportable and not tied to an outlet !
