darkarn
- Mar 16, 2012
I am using USB now but may move to Toslink when I get a dock for my MacBook Pro. I have no plans to use coax.
I am using Toslink now, just that I can foresee that I will want to use Coax eventually (as the Toslink In of the Mimby will go to another computer)
No need for USB/SPDIF converter. Just use something like W4S recovery and it should give great results.
I looked at that, it is way too costly. I just need to convert from USB to Coaxial so that I can use it on my laptop (which is also my main machine)
I'm really thinking of getting the Modi Multibit. I have the AKG K7XX and Vali 2 with an Amperex Orange Label in it.
No DAC yet, other than onboard audio of course. Any reason not to drop the $250 on it? I mostly listen to Apple Lossless or 320 MP3. I have some 192k and what not but will have to upgrade some of my music if I get the MM.
You don't have to upgrade your music (which is what Schiit is all about), just get the Mimby so as to complete your Schiit Stack and you are good to go!
