GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
May 25, 2023 at 4:11 AM Post #6,136 of 9,911
I configured to for a single output, and it makes a difference.
It seems to work better this way;
One thing that's really awkward for me to try is to disconnect the GPS antenna, as the LB is inside the R26, and see if that makes a difference?
May 25, 2023 at 4:16 AM Post #6,137 of 9,911
After about a week of burn-in, I tested the LB clock and compared it to the OCK-1 with two devices: the R26 and the AGD DI-20HE.
I used for the trials the Gustard C2 cable, and a LMR400 cable to which I applied the copper/Faraday tape tweak.
The LB was powered by the 5V/3V output of a Shanti.
With the DI-20HE, the LB does not improve the sound over the internal clock. On the contrary, with the 10 mHz input of the LB, the sound is flatter than with the internal clock. On the other hand, the OCK-1 improves the sound of the DI-20HE with an additional relief/depth.
The LB does improve the sound of the R26, but not as much as the OCK-1.
I don't have a LPS of 7.5V.
Do you think that there's something else that I should try, before asking for a refund?
Not suprised at all here.
LB clock -70 dBc at 1Hz
OCK1 (measured) -91dBc at 1Hz
With the Leo clock not being a hifi device, outputting a square wave for a paltry $200, who knows what internal impedance mismatches are occurring as well.
Unless you’re spending big dollars on a clock, stick to Sine wave and use a low pass filter.
May 25, 2023 at 4:17 AM Post #6,138 of 9,911
I plugged the antenna only for the configuration of the LB.
I do not plug it when I stream music.
May 25, 2023 at 4:30 AM Post #6,141 of 9,911
LB clock -70 dBc/Hz at 1Hz
Unless you’re spending big dollars on a clock, stick to Sine wave and use low pass filter.
Interesting view, but let's wait,rather than assumptions, let's hear Dan's views, once he set the clock correctly for use.
May 25, 2023 at 4:31 AM Post #6,142 of 9,911
May 25, 2023 at 4:38 AM Post #6,143 of 9,911
You need to keep the antenna in ,its works off GPS
But if the unit is in sleep mode, as recommended and proven to be better, all logic/configuration circuitry is off so how can the GPS be actively working? It will only work when the app is showing the unit is connected (green rectangle as opposed to red).......
May 25, 2023 at 4:52 AM Post #6,145 of 9,911
Is it all the logic / functions though? The LB site says sleep turns off the micro controller but without more knowledge we can’t be sure whether GPS operates in sleep mode.
May 25, 2023 at 4:56 AM Post #6,146 of 9,911
“Operation requires continuous presence of GPS signal, however temporary loss will be tolerated seamlessly. Active or passive antennas are supported. An active antenna with 5 metre cable is provided with the device but can be substituted if necessary.GPS acquisition time after power-up is around 30 seconds. If GPS signal is lost, digital PLL will maintains best estimated output frequency based on historical data. On reacquisition of GPS lock, output is seamlessly brought back in sync with GPS reference. Entry and exit of frequency hold is glitch-less.”
How do I tell if the unit is locked onto a GPS signal?​
The two status LEDs on the front of the device will be constantly on.
Also if the device is connected to the software the two warning messages will not be show.
I’m surprised you guys don’t know how your clock works.
May 25, 2023 at 4:56 AM Post #6,147 of 9,911
All we can do is try the antenna in, which is how I have always used it, and then with it disconnected to hear any difference.
May 25, 2023 at 4:59 AM Post #6,148 of 9,911
I don't have the impression that the antenna changes the sound…
Anyway, with a single output, there is an improvement.
I would say that the sound is a bit smoother for the DI-20HE. It is a subtle improvement. It is not as obvious as with the OCK-1.
I try it with my best cable: the Gustard C2.
May 25, 2023 at 5:12 AM Post #6,150 of 9,911
That's why we trying help out in a positive manner, we all humans, and all have different skill sets
