GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
May 25, 2023 at 5:14 AM Post #6,151 of 9,914
The R26 sounds a bit better with the OCK-1. I would say that the sound is more ample. (Compared to LB with antenna, and the 5V/1A output of the Shanti).
May 25, 2023 at 5:18 AM Post #6,152 of 9,914
My guess is the plugging in or out of the antenna will make little difference until the clock drifts. This could take 30 mins or 30 days for all we know.
This is exactly my (admittedly casual to date) thought process on this 👍🏻
May 25, 2023 at 5:21 AM Post #6,153 of 9,914
Have you tried a small weight on top of the LB, it using a lightweight Ali extrusion? It's design brief was for a reference clock device that has to be mobile not a hi-fi device.
May 25, 2023 at 5:42 AM Post #6,155 of 9,914
Yes, that's what I did with 1.2 Kg.
And I configured the LB correctly: put it to sleep with a single mode (a single 10 mHz output from BNC 1).
I'll sum up the tests with my system.
With the present settings (single mode), the LB improves the sound of the R26.
The sound is smoother than with the internal clock. There's no doubt about it.
But with the OCK-1, the improvement is more obvious, and the sound is more ample.
In single mode, it also improves the sound of the DI-20HE, but the difference over the internal clock is very subtle. With the OCK-1, the sound has clearly a greater depth over the internal clock.
The LB is cheaper, and should be a worthy upgrade for someone who needs a single output of 50 ohms.
These conclusions are made with my system. We will see what @Jake2 reports.
May 25, 2023 at 5:45 AM Post #6,156 of 9,914
Try three hard interfaces under the LB not soft compliant material....
May 25, 2023 at 5:47 AM Post #6,157 of 9,914
Worth also pointing out that the LB is capable of two 50ohm outputs at the same time so it could serve two devices.
May 25, 2023 at 5:52 AM Post #6,158 of 9,914
When I configured it to two outputs, it did not perform as well.
In this setting, the sound with the internal clock of the DI-20HE was superior. The sound with the external clock was flatter.
May 25, 2023 at 6:00 AM Post #6,159 of 9,914
From recollection @Dandoudou 's OCK-1 performed at a similar level to a friend's OCK-2 (correct?) so his may be an outlier/high performer...for what that's worth
May 25, 2023 at 6:03 AM Post #6,160 of 9,914
You are right.
The difference between the clocks was very tinny, and we ended by comparing between them on 3 systems.
May 25, 2023 at 6:15 AM Post #6,161 of 9,914
Were you using the two outputs together then, ie both BNC's connected to kit, or was one BNC (output 2) not connected to anything? We know that deselecting an unused BNC output improves the sound. Trying to make things as clear as possible for everyone.
May 25, 2023 at 6:18 AM Post #6,162 of 9,914
Apologies if this is a noobish question but is the R26 capable of streaming local files? I'm not into the whole roon and tidal thing as they just don't have the music I have on my storage drives.
Thanks.
May 25, 2023 at 6:22 AM Post #6,163 of 9,914
"Anyway, with a single output, there is an improvement." With only one output activated, then the red light on the unused one flashes constantly, which I find very annoying. Is this normal, does anyone else find this to be distracting?
May 25, 2023 at 6:23 AM Post #6,164 of 9,914
Thanks.
That's all I use, is local files much prefer the overall sound, using the LAN streamer, Minimserver running on a SMC with LPS and 2.5" 2TB USB HDD attached. Access to files is via a controller app (Jplay or Mconnect for IOS) utilising the uPnP/DLNA protocol. BubbleuPnP and Mconnect work on android devices. wi-fi extender and FMC modules are recommended with a separate switch to keep everything clean on the audio side.
May 25, 2023 at 6:24 AM Post #6,165 of 9,914
"Anyway, with a single output, there is an improvement." With only one output activated, then the unused one flashes constantly, which I find very annoying. Is this normal, does anyone else find this to be distracting?
Blu-tac is your friend...... or you could pop it inside the R26!
