(ALREADY ANSWERED IN PREVIOUS POSTS)
sorry
sorry
Has this been discussed. Is it a empty sd card slot. What is it for?You are right, this is why I find it pretty useless.
If the unit was mine and not a review loan, I would open it to find out if there is an SD card inside where I could install moode os.
On SD card is Linux with "streamer" SWHas this been discussed. Is it a empty sd card slot. What is it for?
so there is actually a OS running on a physical SD card inside?On SD card is Linux with "streamer" SW
You get more complete info if you go to Gustard's web site.so there is actually a OS running on a physical SD card inside?
I haven't opened it so I don't know.Has this been discussed. Is it a empty sd card slot. What is it for?
link?You get more complete info if you go to Gustard's web site.
http://www.gustard.cn/link?
Thanks I found the site and looking at the HDMI/I2S configuration and have a little doubt about my matrix spdif 2... it seems 2 of the pins is named differently on my matrixhttp://www.gustard.cn/
But I don't think that you will find anything about the streamer os and if you can substitute it with something else.
@JackJohnson316 knows all about Pin 15.Thanks I found the site and looking at the HDMI/I2S configuration and have a little doubt about my matrix spdif 2... it seems 2 of the pins is named differently on my matrix
I dont hope I have to pull out some pins on a expensive HDMI cable![]()
Lol I’ve never heard a Sparko preamplifier in a system though I’m sure I’ve had that same look on my face after some Pink Floyd along with some good smoke .One last thing then I’ll shut up , that Sparkos preamplifier with a good quality headphone including the Gustard R26 pick a track that takes you away I’m pretty sure it put a 1000 yard stare on your face
Is the pin out on the Gustard compatible with PS Audio i2s ? ThanksThanks I found the site and looking at the HDMI/I2S configuration and have a little doubt about my matrix spdif 2... it seems 2 of the pins is named differently on my matrix
NegativeIs the pin out on the Gustard compatible with PS Audio i2s ? Thanks
As migo said, it has an SD card for the firmware.Has this been discussed. Is it a empty sd card slot. What is it for?
