for me, the musician does not sound better than the gustard at any volume level. and a gustard is more weightier and bassy for me than pegasus which has a very primitive bass in comparison
I just had the Musician Aquarius with three other dacs , the Aquarius lasted two tracks against the R26 then it was put back in its box and sent home .
I believe that Palyodgree means a good preamplifier can make the world of difference in a music reproduction system. This has always been the way a good music system works, well in my 45 years of experience of listening to recorded music and building systems. I believe that one should not ever underestimate what a good preamplifier can do. The R26 on board preamplifier sounds good out of the box, and it needs considerable pedigree preampfification to make the R26 work better.
If you are after a particular flavour of sound then a preamplifier can deliver the goods, tubes or solid state.
Of course if I have read his post wrong then..... well I still believe that pre is key. In any source of a music system. It is always remarkable what a well engineered preamplifier can deliver.
I should have mentioned that the point of this post is that the R26 delivers fabulous levels of detail and nuance that enables a preamplifier to tailor the sound to the listener, most Dac's do not have the resolution and the all important believable musical element to the sound to make the presentation enjoyable. There has to be enough musically believable material there for the sound to be moulded to the listener, if that makes any sense.....
I apologize drifting off topic however I have to give credence to Sparko Lab preamplifier with that Reed gain , i no longer own the Sparkos however id like to say Wow what a pleasurable volume control that is to use , including a very good headphone section built in.
edit , $2500.00 it’s a stupid good bargain even better bought used .
One last thing then I’ll shut up , that Sparkos preamplifier with a good quality headphone including the Gustard R26 pick a track that takes you away I’m pretty sure it put a 1000 yard stare on your face
One last thing then I’ll shut up , that Sparkos preamplifier with a good quality headphone including the Gustard R26 the first track of music would put a 1000 yard stare on your face I’m pretty sure of that .
That phrase just stuck in my head recently i had just finished listening to Mozart’s Ave Verum David Chesky fantastic recording my wife said the profound look I had on my face was like I was staring over a long distance ,just something about that piece thats deeply stirring.
