May 7, 2014 at 9:56 PM Post #226 of 349
Has anyone ever heard of or used Veritas memory foam earphone tips?  The link below is for the ones that fit 2.5 to 3.5 mm nozzles.  The GR07 has 3.5 mm nozzles.  At the time of this post there are no reviews of the product.  Its pretty cheap too.  Just throwing it out there.  I have been able to get 200 size comply tips on with the use of a conventional pencil for stretching so I may not need to try these out for a bit.
http://www.amazon.com/dp/B00GJPFS20?psc=1
May 10, 2014 at 3:22 PM Post #229 of 349
Comply T-200 fits great so do the Sony's hybrid
Do note the fit is a bit loose to the original foams (only when compared)
Sony's - sounds thin , more treble , less impact, poor seal
T-200 - warm , good impact , little more bass , great seal.
T-200 recommended as of now ( still in burn in period )
May 20, 2014 at 3:35 PM Post #230 of 349
Hey guys, so I lost one of the orange tips for my GR07 but those ones provided the best fit by far. Does anyone have any suggestions for a replacement that's similar size? I'm using the medium black tips and they give a good seal but feel a lot harsher against my ears. Thanks.
May 29, 2014 at 5:32 PM Post #231 of 349
A the comply T-200 are definitely NOT a proper fit for these. I just tried them... they fit very loosely and actually came off in my ear when I took out the headphones. I needed tweezers to get the one tip out.
Jun 26, 2014 at 3:18 PM Post #232 of 349
That might depend ear to ear. Yes they are not a tight fit but they never came of from my use.
Jul 15, 2014 at 11:58 AM Post #234 of 349
Been messing around with tips after getting my gr07. Seems like the purple sony's fit well. I am moving my jaw and these were the ones that stayed in place the most. Is that an accurate test? I have small ears and seems weird the largest tips fit.
Sep 6, 2014 at 2:48 AM Post #235 of 349
Sorry to bump this thread, but I've just got to say that the MH1 tips on these things are absolutely perfect. It brings the mids out, evens out the treble, and even deepens the image. Overall just helps the mix feel more "right", if that makes sense. I've been listening to these things all night in a state of bliss. Big shout outs to @kova4a and @SkiesOfAzel for tipping me off about these on the GR07. If you have a GR07 or Classic Edition, do yourself a favor and try these out.
Sep 6, 2014 at 2:50 AM Post #236 of 349
 and @SkiesOfAzel
Can you link me to these tips please?
Sep 10, 2014 at 6:54 PM Post #238 of 349
I tried the Comply T-200  tips on my GR07s...not a good result.  The openings are too  loose on the GR07 shaft.  Every time I'd remove the IEMs from my ear, the foam tips would stay in my ear.  They'd also often just fall off while handling the GR07s.  Is there any size Comply foam tip that is not too small to fit, but not too large to fall off so easily?  There's been much analysis in this thread, but a lot of different answers as to which fits best.
Sep 10, 2014 at 7:04 PM Post #240 of 349
The Comply T-100 fit really good, but you have to stretch them first.
