r3vengee2
I keep reading posts here talking about how there is an issue with the MW07 plus and Apple devices, something about a codec I think? Is the issue really that big that it should deter you from purchasing it?
Got my T5's! First impressions are fantastic!
Will play with them over the weekend and post my review next week!
Ok guys. I'm 99,9% sure that if you enable AptX in MacOS Catalina, you actually get AptX. Even if it shows SBC when using the "hold Alt and press bluetooth device to see codec in use" method.
You remember I was talking A LOT about the SBC noise with the Senn' MTWs (NFMI)? (the "metallic" noise, almost like something is loose inside the headphone/bud with deep punchy bass?)
Lypertek Tevi (AptX/AAC) and BeatsX (AAC) were used to test.
- First I disabled both AptX and AAC: SBC noise in both headsets, no doubt about it.
- I then disabled AptX and enabled AAC: Catalina shows both use/support AAC, and no noise what so ever in either headset.
- And the exciting bit. I enabled Force use of AptX and disabled AAC: The Tevi plays compact and punchy bass with NO SBC- or other noise at all! Clean as a whistle.
The BeatsX have the same amount of SBC noise as in the first test with both disabled. (that proves that it's not AAC in use.)
The test song where I hear this very easily: (You need high volume to hear the "clinking metallic noise" clearly.)
You also hear it when using low frequencies with this: https://www.szynalski.com/tone-generator/
Using an iPhone 11 Pro with WF/XM3 and absolutely no such problem. Both the phone and the IEM’s are in their respective latest software updates.
Just tested it and I’m on the JR Yamanote line in Tokyo, probably the most Bluetooth unfriendly environment on the planet. Rock solid performance.
https://www.techradar.com/reviews/hands-on-apple-airpods-pro-review
First one out there.
A note for those of you with an iPhone 11:
I just "upgraded" my iPhone 11 Pro Max from iOS 13.2 beta 4 to the final release of 13.2, connected my Sony WF-1000XM3s to my iPhone 11 Pro Max, and tried to record a voice memo -- and the Bluetooth connection dropped almost immediately. And a second time ... and a third time. This is a problem that happened with some regularity before I upgraded last week to 13.2 beta 4, when it seemed to get better -- but with the final release of 13.2 the problem is worse than ever.
The problem is persistent but happens randomly. If I record a few voice memos, the Bluetooth connection will eventually drop -- and the Bluetooth connection will randomly drop during phone calls too, making these earphones essentially useless on this phone. So whatever seemed like Apple fixed in 13.2 beta 4 is now certainly broken again in the final release of 13.2. I've been having the same problem with the Liberty 2 Pros.
Also, when I connect Bluetooth earphones to my iPhone and check the connection speed on my Mac via Console I find that the earphones are generally connecting at very low connection speeds -- 160kbps or 192kbps (in the case of the Soundcore Liberty 2 Pros) or even as low as 127kbps (in the case of the Sonys). (The Jabra 65t's connect at 256kbps, so not all headphones have horrible connection speeds.) The effect of these low connection speeds on the sound quality is very noticeable -- Apple Music sounds like it's transmitting 128kbps MP3s from 2004.
To demonstrate that the problem is with the iPhone 11, I connected the same earphones to my 10.5" iPad Pro and the connection speed is generally rock solid at 244kpbs or 256kpbs. Also, about a week ago I exchanged my iPhone 11 Pro Max for a second iPhone 11 Pro Max because the first was just as bad -- so something is very wrong with Apple's Bluetooth implementation on the iPhone. Frankly, I'm not optimistic that this can be fixed with an OS update -- since these problems have persisted through several iOS updates, it feels more like the problem might be a hardware flaw in the iPhone's Bluetooth implementation. Ugh.
I have the new AirPod Pros coming on Thursday, and I'll bet the connection on Apple's own earphones is rock solid -- but we'll see. Unfortunately, I have numerous pairs of non-Apple bluetooth earphones that are essentially borked at this point. Very disappointed in Apple.
Are others with an iPhone 11 having any of the same issues?
thanks, there are several youtube reviews now out there in the last hour.https://www.techradar.com/reviews/hands-on-apple-airpods-pro-review
Yes, they popped up everywhere A lot of good reviews as well.thanks, there are several youtube reviews now out there in the last hour.
