clerkpalmer
- Dec 16, 2015
Either way getting excited. Mine shipped already. Hoping it’s 2 weeks not 4. Comon Ali!We need a Tai expert here =)
Hopefully asak will translate. I do hope they are exactly like my ZST. Since both have BA/Dynamic drivers.We need a Tai expert here =)
Does the Wavefun charge Type C to C or just Type C to A? Is the seal and isolation better than the Jabras?Oh my, I may have posted my review on the Wavefun X-Pods 3/ Ytom T1/ W1 TWS too soon. I really love the mids on this one. Highs don't extend as well as on the Jabra Elite 65t, but they do offer fuller lower mids and a quicker bass.
On the other hand; I notice I always put the Anbes 359 away after a few minutes now, to change them for a tws I find to sound better - such as the above mentioned or the QCY QS1/ T1C which has just that little extra bass oomph over the Anbes.
This is a great hobby, isn't it?
Early reviews are lukewarm. Apparently very little bass and possibly shrill highs. Maybe they have or will fix them but for now, I’d suggest holding off unless that sound signature is what you like.over 100 pages since the last time i was here, this thread is moving along fast,
Has anyone seen or heard anything about the new Hifiman true wireless? Ive always thought there Headphones where some of the best and hopefully this will hold true with the wireless buds.
I hope that changes. The price is reasonable for a Hifiman product and the stats look really good. Hopefully they re-tune them to add more bass. The Senns are still my favorite sounding TWS and would be hard to beat.Early reviews are lukewarm. Apparently very little bass and possibly shrill highs. Maybe they have or will fix them but for now, I’d suggest holding off unless that sound signature is what you like.
Agreed. I have edition XX and they are just amazing. Hopefully they will fix them. THe Sony May upend your mtw and probably is a better option than the hifiman. I get mine Wednesday and will report back.I hope that changes. The price is reasonable for a Hifiman product and the stats look really good. Hopefully they re-tune them to add more bass. The Senns are still my favorite sounding TWS and would be hard to beat.
I was eyeing those big time! Hopefully they have more volume then the first iteration which was the only reason i sold mine. cant wait to read your impressions on them. If you like them i might have to hit up best buy and get a pair.Agreed. I have edition XX and they are just amazing. Hopefully they will fix them. THe Sony May upend your mtw and probably is a better option than the hifiman. I get mine Wednesday and will report back.
Sounds too good to be true for a Sabbat E12 lol https://www.amazon.ca/BreTT1QIN9-Re...=sabbat&qid=1564133289&s=gateway&sr=8-43&th=1
Anyone tried these before?
https://www.amazon.ca/dp/B07TGBC46P...colid=4G6BQG39EQ05&psc=1&ref_=lv_ov_lig_dp_it
July 27 has come and gone and Anbes 359 still not in Amazon.com stock. There is a potentially dubious third-party seller though. Still better than Amazon.ca with no Anbes 359, ripoff Kissral R18 and UFOs including Monster (although I think that one still seems worth trying). https://www.amazon.com/gp/offer-listing/B07M8LWN2G/ref=dp_olp_0?ie=UTF8&condition=all
has anyone experienced that tws inside it's charging case keep charging when shaken? or is it my tws a little bit unstable because of removing the tips?
is it manually pair as in like new /first pairing? or it's already on the bluetooth devices list, but you have to manually click the name to pair?
if it's the first, try resetting the BT20. if it's the latter, i only experienced it if i use it alternately between several devices. it should however connect automatically to the last used device
from off position, press and hold the buttons until they turn on and off themselves again (usually about 10 seconds process). after that turn them on again like usual.. let them connect to each other first before turning on the bluetooth on your phone
usually it's the same procedure to master reset most TWS
