Oct 25, 2024 at 6:46 PM Post #66,271 of 70,713
I still can't get the KZ Xtra out of my mind. Had the cursor on the purchase button all the time.
I saw reviews comment on how good they sound, good tech (DAC, DSP, AAC), good battery life and have a low latency gaming mode. Only thing making me hesitate is no volume control. It's one of the few things I need, because changing system volume on PC is noticeable when recording and not practical to do with keyboard, but also with a phone it is inconvenient to always grab the phone to change volume. Man if they only had volume control...
Is there a better way to control volume on a PC? With my IEM I use a Fostex volume rocker, but is there an equivalent for wireless? What should I do, go for the Xtra or try the Moondrop Moca?
Oct 25, 2024 at 9:17 PM Post #66,272 of 70,713
Finally decided to grab that six pack when it went back on sale...
Just having a listen straight out of the box after the perfunctory FW update and switching to LDAC. No other setting touched just using them at their raw sound signature.
These are pretty damn amazing for the price I paid... have to see after I tweak them a bit and then doing some actual comparison how they stack against my somewhat flagship weighted collection.
I paid $91CAD after taxes. So pretty darn cheap...
Oct 25, 2024 at 9:25 PM Post #66,273 of 70,713
So between the XM5 and the AZ80, I ended up getting the Technics AZ80.
Is it normal LDAC always sticks to "best effort" in developer settings? I noticed Technics app says if the maximum LDAC rate (990) is selected at the OS level, change it to best effort. I even tried Bluetooth Codec Changer, same thing. Are the AZ80 not supporting the highest LDAC setting? That would suck.
Codec changer should handle it. I had zero issues.
If you don't love them, aviot te zx1 is the set to beat, imo
Oct 25, 2024 at 9:26 PM Post #66,274 of 70,713
My Amiron 300 does save and store custom EQ but after some time (or actions) it reset to default. Someone else noticed this?
The lower volume while using EQ is due to auto gain control. If you don't tweak massively the volume levels are just fine.
Any comparisons? I have a soft spot for beyerdynamic
Oct 25, 2024 at 10:00 PM Post #66,277 of 70,713
Oct 26, 2024 at 3:39 AM Post #66,279 of 70,713
.... I left the Windows ecosystem 17 years ago. No regrets (other than Apple's use of AAC only). So figuring out Android has had a steep learning curve. ....
Actually, Android is basically on Linux based OS. If you know Linux, it shouldn't be that dramatically different.
I assume connecting the FiiO to your PC should show up as a new drive. It may not because the drive is formatted in MacOS friendly way; although, Andriod usually used file format that is friendly to both Windows and MacOS. It doesn't give the fastest speeds for file transfers.
Oct 26, 2024 at 4:03 AM Post #66,281 of 70,713
This is getting ridiculous. I picked up another clearance TWS at Walmart yesterday, this time a Skullcandy SESH ANC. It has an excellent download app for IOS and integrates
seamless with it. It sounds so much better than the $39.00 price would suggest (reg $79). I'm having a blast picking these clearance units up at Walmart. Y'all should stop off at your local Walmart, just to check it out. Of course it's a hit/miss thing... Good luck..:beerchug:
My Walmart deals. All new in retail box (no open box)
Sony XM4 over ears. $149. (last year)
Bose QC 45 $140 (last year)
Samsung Galaxy Buds 2 pro $65 2024
Skullcandy SESH ANC $39 2024
Sony C500 TWS $29. 2024
I think more, but this old goats memory ain't what it use to be.. :L3000:
Isn't it amazing how TWS sound even sweeter at half price? This is why I get my stuff usually gently used at maybe 60% of original price at e-earphone
Oct 26, 2024 at 6:04 AM Post #66,283 of 70,713
Thanks for sharing! Im gonna wait for the new FiiO hooks, if their release ends up getting more delayed ill try these out
I just can’t believe it’s been about three years since I owned the UTWS5 and here they are again but without an upgraded Bluetooth chip. The only thing they changed is the charging contacts. The QCC5141 is like 6 years old now. With an early version of lossy aptX Adaptive. So, much has advanced since then. These should be coming with the QCC5229 now. Even the version of LHDC they use is old. I think it’s 3.0. This is why I’m going to great lengths to get these “Dream of Ancient Skies” ones, because I’m a demanding tech-head and nobody else seems to making earhooks with the latest premium chips. Once you go lossless, you can’t go back. 🤣
Hopefully the UTWS17 will surface next year with the QCC5229 or better still, the S7 Pro chips that do up to 24/96 lossless over Wi-Fi.
Oct 26, 2024 at 8:53 AM Post #66,285 of 70,713
I enjoyed the ZX1, but for my use, I needed something with very good ANC and a lower profile. ZX1 are huge.
True enough. Noble h anc has the best anc on a tws I've heard to date. Gym is nearly totally silent.
