Aug 10, 2024 at 2:59 AM Post #64,278 of 70,064
This from Ebay AU...looks like there is the ZX1 model (red) new available as well.
Nice, and please be aware that TE-ZX1-PNK has different tuning than TE-ZX1. I heard both before purchasing and preferred PNK.
Aug 10, 2024 at 7:39 AM Post #64,281 of 70,064
How do they compare to the liberty 4 NC?
To my ears, the bass is more pronounced in the 4NC. It is a signature that I prefer more. I have tried my personal preference and all of the presets that I felt would work for me.
Why do you return them?
They are quite a buy for their price but I have other signatures I enjoy more in my "collection".
Aug 10, 2024 at 10:21 AM Post #64,282 of 70,064
I like the sound signature of the 4NC too but it feels a tat more bulky and doesn't sit flush to the ears to my preference. Is the earfun smaller in size? And is the sound quality not worthy enough for compromise?
Aug 10, 2024 at 10:36 AM Post #64,283 of 70,064
Started with balanced, played with dynamic and the other presets and ended with this for a custom EQ. Had the bass cranked a bit higher as well the treble but dialed both down. NOTE: I can't really hear 16Khz anymore so I don't generally bother adjusting unless I can hear it change the sound...
Will have to do some A/B/C testing but pretty sure these are going to beat the Sony comfortably and I think likely the Elite 10 as well for SQ.
I can only go from memory but I think these already have more detail than the GB2P even without UHQ and they are less grainy sounding. I like the planar tweeter.
I find that the expansive sound stage and detail retrieval are fantastic on these. Make sure in the buds settings you have it turned on for it to adjust the sound to the fit in your ear. That seems to really improve the sound quality for me. I also have Dolby Atmos on in music setting.
Aug 10, 2024 at 10:55 AM Post #64,284 of 70,064
My triumph finally arrived. They are the king by a decent margin. Keepers for sure, and they fit better than the Prestige, as the nozzle is not as wide. They're great. Hoping they add ANC with a software update in the future.
Aug 10, 2024 at 11:22 AM Post #64,285 of 70,064
Do you mean this setting?
I use Atmos but just made sure it was set to music. I also do the hearing test there. So I set the EQ back balanced and rerun the test. Quite liking the sound after the little tweaks. Also toying with a basic v EQ like this.
Aug 10, 2024 at 11:54 AM Post #64,286 of 70,064
Yes that setting.
Also I have also tweaked the bass a bit up and slight decrease around 1-2k.
I got the new fold so I have the uhq codec though not the source material lol.
Sound is so clear wide and full.
Aug 10, 2024 at 12:02 PM Post #64,287 of 70,064
I am sadly waiting.... impatiently... LOL
I have to admit more than a little frustrated yesterday when I figured it out. Had to wait 2 weeks only to find out I can't even get the max out of them yet...
Setting my first world whining aside...
The buds and the new Watch 7 both redeem Samsung a bit for me. If these both had been more of the humdrum updates I would have been pretty upset. But both actually seem like a pretty good step up with the GB3P being the bigger step up.
The GW7 with the new update now has 40-50 battery life when I charge it in the morning. So the update helped.
Aug 10, 2024 at 7:13 PM Post #64,288 of 70,064
Is the ANC a feature they are promising???. They would need to have the 3 mics available on the hardware
Aug 10, 2024 at 7:56 PM Post #64,290 of 70,064
Guyz, I'm trying to decide between Huawei freebuds pro 3 vs Samsung buds pro 3. Which has the best call microphone experience? freebuds pro 3 doesn't sound bad right?
I will only be able to comment on the Gbuds 3 Pro after making some calls and getting some feedback.
Are you using a Samsung high end phone or a different brand of Android? I am currently using an S23 Uktra that does not have the ability to do UHQ yet. So am limited to standard SSC or AAC and while limited can say these sound very good. But you will be limited to just AAC on anything other than Samsung so this needs to be considered.
