helmutcheese
Go by your ears not a chart and I would bet someone else's chart would look different.
Go by your ears not a chart and I would bet someone else chart would look different.
I don't normally read charts but I guess this is saying you would barely hear anything above 8 kilohertz? I don't know if my ears are even capable of arguing with that, but what sort of sounds are we talking about in that range?Do you even know how to read such a chart? And did you go to their website to check if other earphones they measured look legit?
I agree that someone else's chart would look different, but that's because people use different measurement rigs and different compensations. That's why one should only compare charts from the same rig.
I did the latter and most of their measurements of other earphones I know look legit. So I have no reason to assume that these particular measurements of the Ace/2 are off. All the more since they measured two models and got the exact same results.
As in my previous post, just ignore the 8kHz peak and anything above it (on all graphs).I don't normally read charts but I guess this is saying you would barely hear anything above 8 kilohertz? I don't know if my ears are even capable of arguing with that, but what sort of sounds are we talking about in that range?
Hmm, color me surprised. This doesn't look like the treble performance I'm getting from my Linner Deluxe.
Seems like not all MEMS are equal. Or DSP is messin' with the FR.
If you can get your hands on it the Falcon Max has LDAC.The only issue for me is the 6 hour battery life and that is without ANC and unless otherwise stated will be AAC@50% Vol.
The Linner vs. the Creative driver
The enclosure, the chip(they don't use the same one do they?), the supposed custom tuning Creative touts, different tips. No reason they can't differ similarly as different BA models do in the highs.
Honestly tempted now to order the Ace to hear / measure them myself...
No so much that, but I am getting one really weird behavior where the soundstage sometimes goes from a relatively intimate state to a wide one on its own... and just as I type this I think realized the reason: I'm using the LE Bluetooth option on my Pixel 8, and I have Spatial Audio checked as well. I had never heard any effect from the Spatial checkbox when I tried it on anything else and figured it was some Pixel Buds-only feature, but I guess it's also built into the "Experimental" LE implementation, which explains why it's sporadic (experimental = buggy). Apologies for such a narrow use case, but other Pixel + Aurvana Ace users might want to try it out.Has anyone else had issues with static with the Ace 2? Whenever I open my mouth too wide or occasionally just when looking down the left side will get crackly. CS had me do a master reset, FW update, and another master reset and now I'm sending it in for an exchange.
I also had issues with low volume occasionally when reconnecting with my phone which usually resolved by turning off/on.
