@hifi80sman - I'll c ur Comexion and raise you a CUFOK:
https://www.amazon.com/gp/product/B07MFHJ6MX - The only reason I got these aside from the IPX7 is the seller claimed it had Airoha AB1526P with AAC but upon receiving it, I'm not able to connect in AAC. In hind-sight, it's nearly identical to the Comexion aside from the better WR rating and the charging case that can also act as a portable USB charger.
Sadly it was the same story with this one:
https://www.amazon.com/gp/product/B07L9P6CLQ (no AAC either despite seller claims). Really wish these guys would get a grip on their product specs. I wonder if somehow they didn't enable it (I don't see why they wouldn't given it's a selling point) or if perhaps there may be a bait-n-switch with the OEM's promising the 1526B but utilizing a cheaper chipset instead. The connection isn't great with this one; a simple test I always do right after getting a TWE is to just cup my hands over each one while worn to see if the signal cuts out between them. If it does, it's USUALLY (though not always) a VERY good indicator I'll encounter connection issues as I did with the MPow T5's which failed that test badly. Not so with the Aermoo B3's which are rock solid connection-wise.
I'm done chasing... decided to give in and grab a MW07 just so I have a high-end reference point to qualify when I say something sounds good or bad.
P.S. Aside from the first, some other more interesting mfr names of TWEs I found on Amazon:
REFURBISHHOUSE <- while I'm all for getting discounts on refurb's, not really sure they realize this has a negative connotation for new products
G-WACK
Mebuyz
Tiamat < 80's D&D cartoon anyone?
Qjuxron - is the Q or the J silent?
ZFKJERS - Qjuxron? Not impressed! I'll see your double-consonants at the start and double that
