Apr 1, 2022 at 3:07 AM Post #44,146 of 70,081
Did you try the blow or suck to try and loosen a collapsed diaphragm thing or the cleaning or filter stuff mentioned there? It might be a physical thing that some seem to have cured or it could just be the driver is broken where it can't be fixed.
If they are being reset the volume should go back to even on both sides and whatever level it was out of the box.
Hi, yes, also tried, to no avail.
Must be a dodgy driver in that case,... but paired to a mac, and altering the volme per channel, chanel 1 controls both left and right... suggesting to me the hardware has gone wrong...
cheers!
Apr 1, 2022 at 5:59 AM Post #44,149 of 70,081
Fiio seems to be entering the TWS market for reals with the FW5...I'm guessing the hardware will be amzing as always and the software severely lacking...:/
Apr 1, 2022 at 8:35 AM Post #44,151 of 70,081
Apr 1, 2022 at 9:07 AM Post #44,153 of 70,081
Apr 1, 2022 at 9:56 AM Post #44,155 of 70,081
The Noble Fokus Pro looks to be (about) what I've been waiting for, but think it's too big for my ears. Also, no higher-res codec such as ldac? It's just too much to gamble "trying it out."
Hopefully a few more brands and another generation or two will make the better set: conventional cIEM look/fit (not a big bolt that sticks out of your ears), great sound (either a well-tuned hybrid set of drivers or capable DD), consistent BT radio performance (no or few dropouts and decent range), good amping with plenty of volume, and high quality codecs. It's getting closer, but not there yet.
Apr 1, 2022 at 10:43 AM Post #44,156 of 70,081
Apr 1, 2022 at 11:40 AM Post #44,158 of 70,081
I don't know where you guys are finding the UTWS5 (2-pin). Every time I'm motivated to look for it, no one has it. And I mean NO ONE.
Edit : I've looked :
Audio46
Amazon
HiFiGo
Linsoul
eBay
AliExpress
I got the 2 pin when they came out and I haven't seen them since. They quite literally get bought out thee second they re stock
Apr 1, 2022 at 11:48 AM Post #44,159 of 70,081
Audio46
Amazon
HiFiGo
Linsoul
eBay
AliExpress
I'm going to buy the mmcx and a 2 pin adapter.
Apr 1, 2022 at 2:16 PM Post #44,160 of 70,081
