erockg
They’re vacuums are a godsend with a toddler!This is something I never thought I'd see in headphones. Air purification
https://www.dyson.com/wearables/dyson-zone-air-purifying-headphones/announcement
Do I have to call the authorities?? There are child labor laws you know.They’re vacuums are a godsend with a toddler!
Start ‘em young!Do I have to call the authorities?? There are child labor laws you know.
I guess it is never too early to learn the value of a days work.![]()
Next we will have soul purify headphones lolThis is something I never thought I'd see in headphones. Air purification
How do you compare the yamaha to the cks50 and the az60 in sq, anc and mic quality?Got a basic case size comparison...
TW-E5b case is about 2" tall and 2.5" wide.
Tip rolling is a hoot. The buds fit a certain way and lock in so they keep near the same depth so some tips just like the stock medium might not seal as well as they can since you can't push them in more. Most tips really sound good but different. Haven't gone through many but not as easy here to discard.
Didn't take very long for them to clean up on the sound. I think the bass may take more time but not much run in proved to up the detail and show more clarity.
So far excellent and another level toward wired sounding. These will be well regarded.
I bought the AT instead of the AZ60 since I have some devices that don't do LDAC but only aptX codecs. So, I can't tell you about Technics. The Yamaha can have quite good passive isolation but they are just about the SQ and only do ambient and make calls. They are not an ANC model which is fine as that keeps the AT with a job to do.How do you compare the yamaha to the cks50 and the az60 in sq, anc and mic quality?
I finally caved and bought a good IEM Fiio FH5 and the UTWS5 and now rarely use my actual TWS anymore. The over ear design is pretty comfy and if you have comfy IEMs they become really hard to beat as a combo. If you have a favorite IEM already it also save you having to find its TWS comparable...Think I'm going to return the Liberty Pro 3 and get the Fiio UTWS5 and just use my existing IEM's. I think the behind the ear fit may suit me better.
Anyone use these with glasses?I finally caved and bought a good IEM Fiio FH5 and the UTWS5 and now rarely use my actual TWS anymore. The over ear design is pretty comfy and if you have comfy IEMs they become really hard to beat as a combo. If you have a favorite IEM already it also save you having to find its TWS comparable...
