dweaver
- Dec 23, 2008
Thanks @BooleanBones I agreeTo be honest, I would not spend the money on the XM4s if you are happy with the AZ60s and they are comfortable for you. I have both and don't see the real value in snagging the Sony's on top of the AZs. I do like both a lot, but can't say that you will be doing cartwheels if you were to purchase the Sony's on top of what you have. In my opinion, it's an either or scenario with those two and not both (unless you have a collection like @erockg)
I have only owned one IEM that managed tight hard booming bass, large sound stage and 3D imaging all in one product and that was the XBA-Z5 using the balanced cable on my Pono Player. It was not a balanced signature, but it was amazing. But that's also a $700 IEM with an expensive (at the time) specialized HIFI player using the balanced cable to achieve the magic.
I have owned 2 different hybrid TWS, and several high end dynamic drivers models and none of them have captured that type of technical ability and at the state of TWS technology today's I don't think any manufacturer can. So then you have to pick you poison. Do you want a large sound stage (AZ60) then you give up a harder hitting bass. Do you want a richer sound (MTW2) then give up a bigger sub-bass sound. Do you want hard hitting tight bass (WF-1000XM4) then give up the big sound stage and upper treble sparkle.
That's my suspicion anyway as I have not been able to try the MTW2 or WF-1000XM4.
