erockg
Jabra 85T too. Sadly, they were 40% off yesterday on Jabra.comBose QC or Soundsport are solid and don't fully seal.
Honestly, the setup I have blows away all my TWS soundwise. With the SE846s I'm listening to Pink Floyd's Momentary Lapse of Reason right now and the separation, clarity is just beautiful. Clean bass, deep but zero mud. Just took a phone call and it was perfect. Yes, they do go in a tad deeper but less than the Klipsch. The fit is snug and stable.Do the shure iems require a pretty deep insertion? How's the sq compared to the higher end tws?
Yeah, I had already figured that option but being an old technician from way back any point of break in connectivity is just another opportunity for troubleLOL
Well, by the time they break I'll probably have moved onto the next thing. You know this tech changes so fast it's hard to keep up. But keeping up is part of the fun.Yeah, I had already figured that option but being an old technician from way back any point of break in connectivity is just another opportunity for troubleLOL
I hope they sound great. Tranya makes good stuff. The 4 mic has me intrigued and low latency. I hope I really like em. I'll post about my thoughts.Looks a lot like the new Back Bay audio model, Tempo 30. Starts with a "T" 30 and T20. IPX 7, bass and normal sound modes and that shape...
Back bay looks a little nicer but seems to have a slimmer case and that would knock off one charge. Back bay is cheaper. Also have low lag "movie" mode but the back bay have 8mm drivers and not 6mm.
I hope they turn out good.I hope they sound great. Tranya makes good stuff. The 4 mic has me intrigued and low latency. I hope I really like em. I'll post about my thoughts.
Pretty limited instrument separation/3D imaging, should be priced at 500€ max and I wouldn't pay 500€ for it. There are better alternatives at that price. LCD-i3, for example sounds much much much better. FLC8n, for example, a 300€ IEM, sounds better in all fronts. It was not a fair comparison, but I've comnpared them to QDC Anole VX and the difference was night and day. So much, I thought SHURE is really exagerating on the price. I've gotten Anole VX used for 1100€. That thing sounds as good as my ADAM A7X Studio Monitors.
I’m at a island in the aegean sea and far from the next cell tower - sometimes no internet all all. What are you need to know about the H95? There’s also a very good thread here about itWith the ease of returns at B&O, they are very tempting, especially after listening to the EQ SQ. Think @pitch_black should chime in here. He has a set![]()
Nice. I actually bought some and have been enjoying them. I did spend some time going through the thread. Thanks.I’m at a island in the aegean sea and far from the next cell tower - sometimes no internet all all. What are you need to know about the H95? There’s also a very good thread here about it
I also have sand color….. your new set is black?I've been using a new pair today and I'm not having the same pop issue on the tracks I've tested. Will report back if they suddenly occur. I truly love these B&O EQs.
I like them very much but at these times fiddling with the mask i find the EQ more convenient at the moment. But every now end then I sit at home listen with them for many hours.How do you like your H95s? I probably don't want to know the answer, but curious.![]()
Yeah, went with Black.I also have sand color….. your new set is black?
