so the Z7 currently is better than the M&D MW08S you mentioned previously?
After listening a couple of hours today, this is my placement sound wise.
1. XM4 (with Final E Type tips) - Most balanced. Punchiest bass, most detailed and crisp highs.
2. Pureplay Z7 (sounds good with Final E - Spinfit - JVC Spiral Dots) - They are still somewhat darker/warmer than the others, included the APP and MTW2.
3. MW08S (due to the oval and big stem, I've just tested with the included tips (foam and silicone)) - 3. place mostly because of too much bass with Max ANC, and not have the possibility to EQ it.
But the difference is marginal. So marginal that the features you want and/or price decides what you choose.
Fit, ANC, Ambient mode, Battery life, Case size, Codecs, Looks/Build quality etc etc
I actually think I'll keep the MW08S for the total package.
I'll keep the Sony because of the SQ, and it's great using toghether with my BTA30 and LDAC codec.
I will also keep my Airpods Pro. My goto buds for phone calls, watching series/movies from Apple TV 4k with Spatial Audio and I love the fit/comfort, the small case etc.. The most versatile buds IMO. They sound good as well with the ePro horn shaped tips. (AP00)
I guess I'm selling the MTW2 and the Z7.
Remember, this is my experience, with my ears
