clerkpalmer
- Dec 16, 2015
If it was the same vendor I’d do it but the vendor who sold me the first ones don’t carry the McLaren.What are you going to grab more? That's what you stick with.
Other than the design, do the McLaren tuned differently?Yep ok thanks. Was having trouble and didn’t realize they vary in width and length. Really enjoying these. More impressions to follow. Wishing I had gone McLaren now that I’ve heard them. Can’t bring myself to return just to get McLaren can I? Hate to cause a vendor to lose money on such pettiness.
And it comes with a dual device wireless charging pad.Other than the design, do the McLaren tuned differently?
I a few days ago when I checked them on Amazon the price difference was quite a lot.
There are a few suggestions on non foam tips here recently. I landed on the Final type E TWS tips that I ordered from Hong Kong (MTM Audio). I have also used Crystal Sedna and the EPro TWS tips. I like those as well, but the Finals won my choice for use. @miserybeforethemusic has some really good posts on TWS tips for your reading pleasure in this thread as well.Thanks everyone for very quick feedback. Need to play some more with all this tomorrow. At least I tested them now with some SpinFits on. Very nice, Test says both ears air-tight but I wouldn’t say it’s an improvement, but so much easier to put out and then back in again.
Carbon fiber case too. I'll have my McLaren version tomorrow.And it comes with a dual device wireless charging pad.
I have a set of final type e TWS from mtmtaudio on the way!There are a few suggestions on non foam tips here recently. I landed on the Final type E TWS tips that I ordered from Hong Kong (MTM Audio). I have also used Crystal Sedna and the EPro TWS tips. I like those as well, but the Finals won my choice for use. @miserybeforethemusic has some really good posts on TWS tips for your reading pleasure in this thread as well.
Tuning is the same.Other than the design, do the McLaren tuned differently?
DIRAC is one of those guys like Dolby Labs; the Monoprice THX 788 amp utilizes their DSP for a pretty effective software crossfeed. They're more known for high-end automatic room calibration (similar to REW, but more hush hush).So these Klipsch come with something called Dirac HD Audio. Not entirely sure what it does but they are unlistenable without it on. Makes me wonder why they bothered allowing you to turn it off. Sound like 10 dollar ear buds when toggled off. Reading up on it now. Seems like some sort of custom optimization software that is different than EQ.
There does seem to be a sense of openness and soundstage that is greater than I typically get in a tws. These are very very good sounding Buds.
Well it sounds pretty damn good.DIRAC is one of those guys like Dolby Labs; the Monoprice THX 788 amp utilizes their DSP for a pretty effective software crossfeed. They're more known for high-end automatic room calibration (similar to REW, but more hush hush).
That's what matters, then. They're smart cookies; just a difference recipe than the more well-known guys.Well it sounds pretty damn good.
Experiment with the tips. For me, I had to use the larger tips for the T5 and T5 IIs. Definitely made a difference with the stock sound. Also, the McLaren T5 II non-ANC version came with foam tips. Maybe you are, but if you aren't getting a good seal, email or call Klipsch and see if you get get the foam tips.So these Klipsch come with something called Dirac HD Audio. Not entirely sure what it does but they are unlistenable without it on. Makes me wonder why they bothered allowing you to turn it off. Sound like 10 dollar ear buds when toggled off. Reading up on it now. Seems like some sort of custom optimization software that is different than EQ.
Thanks. I’m at large already and thinking I may need to go xl and I usually go medium. I’m not a fan of foams generally. I’ll be interested in hearing your thoughts and whether the sq is better with the new drivers and the Dirac.Experiment with the tips. For me, I had to use the larger tips for the T5 and T5 IIs. Definitely made a difference with the stock sound. Also, the McLaren T5 II non-ANC version came with foam tips. Maybe you are, but if you aren't getting a good seal, email or call Klipsch and see if you get get the foam tips.
Tried .. not finding that setting .. any setting i find is rather bare boneDownload the Sony music center app, connect your WF1000XM4 or any other LDAC capable device and there will be a setting in the app to have LDAC prioritize sound quality. This way you don't have to go into the developer settings each time.
