Just discovered this---love the ag TWS04K-----
https://www.a-g-japan.com/tws05k
TWS05K
Achieve clear vocals that approach your ears with 2 dynamic drivers . A completely wireless earphone that is recommended as a sub-machine for enthusiasts, and also has waterproof performance.
The " TWS05K " is a model positioned in the K series aiming for sound quality suitable as a sub machine for enthusiasts .
The driver unit, which is the biggest feature, has two 8.8mm dynamic drivers arranged in tandem to make the sound thicker and reduce distortion. This achieves a sound that combines clear vocals that approach the ears and a tight bassline.
The sound quality of the left and right independent earphones is often not focused on the speaker part, and the sound quality is adjusted by relying heavily on the equalizer on the software, which causes the sound to be tired to hear especially in the high range. increase. The current situation is that there are many unbalanced products, such as the low frequencies being overemphasized to avoid such a phenomenon.
In TWS05K , after pursuing the acoustic characteristics of the speaker so that the sound quality is sufficiently satisfactory even without an equalizer on the software, only the part of the high frequency range caused by Bluetooth ®︎ is slightly corrected with the equalizer. I'm taking it. With such technical backing, we have achieved both clear vocals that approach the ears and a tight bassline.
In addition, the TWS05K is water resistant, so you can use it with confidence even in sudden rain.
In addition, there are plenty of accessories. The earpiece is newly designed for completely wireless earphones, and comes with 5 sizes of final " TYPE E completely wireless dedicated specifications" . The earphone body and charging case have a matte paint finish that is not slippery and stains are not noticeable.
It is a model that we can confidently recommend to enthusiasts.
* TWS05K is an
e ☆ earphone limited sale item .
