Robius
- Jan 9, 2012
That's juicy.TWS with LDAC... progress (at least for Android aficionados)...
https://store.hiby.com/pages/hiby-wh2
Still blows my mind why they won't just work on development for the WH3. I'm genuinely concerned. that it seems like they're just going to abandon development, rope in a few new customers, and repeat the process.I noticed how Hiby didn't mention anything about the battery life for their upcoming LDAC tws...
New development...the issue will probably follow whatever bud you pair to your device first. Just did a master reset, then attempted to switch from High Performance to Low Power mode. Right bud works flawlessly now, but the left is causing me endless grief now.Did yours shutdown before or after the latest firmware or both? Mine have been doing this lately or losing bt connection and re-establishing. This did not happen prior. Also, phone calls have weird pops now. The latter could be from my dropping them but not too sure.
No noise during calls, but I have been having that timeout issue that the most recent firmware update was supposed to fix. I don't get random dropouts, though. Can practically set my watch to it.
As usual, the Right ear is the culprit, even though both are allegedly running firmware version 1.4.2 (or whatever the most recent one is). Maybe it's time you and I do the ol' Razzle Dazzle Reset. I plan to finish this Tipper album, then finally pry the B2 out of my ears because they sound so flipping good running off the CF01. Not quite DK-3001 Pro clear, but very musical nonetheless.
I don't think a factory reset wipes the firmware back to stock, which would be massively helpful. Just floats on whatever the current version is.Just did it again. Fingers crossed. Looking around to see if possible to downgrade. Because im still on 1.4.2 after factory.
Don't know if you mean the battery life of just the earbuds themselves or overall, but I've had issues with the earbuds staying on when I put them in the case. Usually causes an annoying whistling sound and sometimes I just have to take them out of the case and let them drain completely before putting them back into the case.I then got the SoundPeats T2 ANC, again glitches in that they randomly decide to turn off etc and battery is nowhere near stated even at lower than 60% volume (again many have same issues).
Same. I now have more TWS than I know what to do with and I just rotate depending on my mood. But they all have their own weird quirks that hold them back from being daily drivers.I do not think there is any ideal TWS out there at any price, I have had Sony/Bose/The high end Anker SoundCore models and OneMore models.
I assume you closed the lid as they will stay connected if not and connect as soon as you open the lid again.Don't know if you mean the battery life of just the earbuds themselves or overall, but I've had issues with the earbuds staying on when I put them in the case. Usually causes an annoying whistling sound and sometimes I just have to take them out of the case and let them drain completely before putting them back into the case.
Yeah, I did close the lid. They still stay on at times. I'll even check to make sure its closed and then see my music still playing and my bluetooth settings saying that its still connected.I assume you closed the lid as they will stay connected if not and connect as soon as you open the lid again.
When they do not act up power on/off/pairing alerts in my ears randomly they run just about bang on 6 hours with ANC @ 13% Volume playing Brown Noise, they are supposed to get 7.5 hours with ANC @ 60% Volume and 10 hours without ANC @ 60% Volume.
I could not use these for music during the day out and about as they have no Previous Track touch only Next Track which is totally lame.
Didn't realize there were so many OnePlus users here. Glad to know I'm in company...Quick update on the B&W PI5
Noticed that one of TK33's phones is the 8t. It happens to be my primary phone as well. Although I'm not sure it mean's much.
Anyway, I decided to do some testing with my older phone, the Galaxy S10e, and initially things were going fine. It connected just fine and the connection was stable, this was a few hours after I tried listening to them with my 8t right next to me and they could barely go more than 2-3 seconds with out the connection getting choppy. Still had the issue with playback getting choppy when trying to get the app to recognized them, but after the app recognized them it was fine.
Then I moved onto using my chromebook. It connected fine and for around 1.5-2 hours playback was fine. Tried doing a distance test and range was pretty disappointing. I left the chromebook in my room and walked to my kitchen before it completely disconnected. With almost all of my other TWS I'm able to walk beyond the kitchen and into the living room before the connection gets unreliable or completely disconnects.
After the listening session with my chromebook I decided try connecting back to the S10e. And it was a no go. The left side was the only one connecting. No matter what I did I couldn't get the right one to connect (unpaired from the settings on my phone, tried taking out the right earbud first, tried taking out the right earbud only). Didn't really care for doing another factory reset so I just gave up.
These past two days I went back to my 8t and so far performance has still been subpar, but more doable. Still get way more drops and choppiness than I do with my other TWS, but its at least been a bit less frequent. Just disappointed that I paid full price for these. Kind of shocking how bad the connectivity and app perform.
I might just try it. I did switch to SBC at one point, but it didn't sound nearly as good as far as I can remember.Didn't realize there were so many OnePlus users here. Glad to know I'm in company...
Is it possible that the cutouts you're experiencing are a codec issue? I was dealing with similar artifacting/cutouts with the Noble Falcon Pro and it took me going into the Developer Options to manually select aptX instead of Adaptive. Try swapping the codec to see if the issue persists. Could very well be that all of the B&Ws are just completely borked from the get-go, but this is at least something you can do that's easily reversible and shouldn't take much time at all.
Quick update on the MT front: I completely reset the MTs, did the whole Mode swap thing using the Pixel 3a, and then did a supplemental pairing with the 8T, starting with the Right bud. Running tracks in Neutron now to hopefully see if I can recreate this issue. I'll keep everybody posted.
At least for the NFP, the difference in quality between aptX and "Adaptive" was pretty minimal. Don't think you'll see the same degradation you did with SBC, but I can understand how frustrating it is not getting all of what you paid for.I might just try it. I did switch to SBC at one point, but it didn't sound nearly as good as far as I can remember.
Maybe that's a sign Sony xm4 will have LDAC?? I don't see Sony giving right to another TWS company to use LDAC if Sony also won't be using LDAC themselves in their own new upcoming TWS. It would be a massive failure on Sony's end imo, and I can't see that happening.TWS with LDAC... progress (at least for Android aficionados)...
The app is terrible. Stutters whenever I try to connect and noticed I had to close all apps sometimes to get it to update (just gets stuck on the same battery level). Galaxy S10e is probably using aptX and your 8T would default to aptX adaptive I think so that may explain the performance difference.Quick update on the B&W PI5
I think all newer Android phones generally do. Works better on some vs. others. My old Samsung phones had it but didn't work as great as it does on my LG V60. Works fine on my OnePlus 8T too. You don't need a Sony phone to use LDACMaybe that's a sign Sony xm4 will have LDAC?? I don't see Sony giving right to another TWS company to use LDAC if Sony also won't be using LDAC themselves in their own new upcoming TWS. It would be a massive failure on Sony's end imo, and I can't see that happening.
Do all phones support LDAC or only Sony phones??
Things get weird when you actually try to look into which bitrate you're effectively using. Some phones default to the 660 middle-ground setting. Some don't tell you at all. Some let you select 990, but there's no way of verifying that's the throughput you're getting.I think all newer Android phones generally do. Works better on some vs. others. My old Samsung phones had it but didn't work as great as it does on my LG V60. Works fine on my OnePlus 8T too. You don't need a Sony phone to use LDAC
