Coop
- Feb 14, 2008
I have narrow ear canals, and I also own the MT and the TWS600. Of the 4 pairs of TWS I own, the MT are the worst at fitment and comfort, though I have overcome it a bit by switching tips on them. I am using the Spinfit CP360 Small/Medium.
They do fit better, but you must be precise in dropping the buds into the case or you might not get them to contact the charging points. This is because they are just a bit longer than the stock tips (though not by very much at all). I would almost call the stock tips bordering on proprietary. They don't, go into your ears, but span across your canals to make the seal. Sometimes this can make simply smiling or moving your head lose seal.
With the Spinfits in place I have not had this issue since, but they take a little longer getting them into place to begin with. I would say that you should order them from someplace you can return them if needed, because they will either fit, or they won't. There is not a ton of large adjustments available (more like fine tuning) to be had.
Curious as to what "for all the TWS600 reasons" mean to you? I would not have paid the original asking price for the shortcomings in the tuning (to be honest), but I got them for $49 off their site, and with some EQ work, they sound fantastic to me. They are not very good at call quality, and don't have any features to speak of, but just for listening to music, they are great. Also keep in mind, I add a lot of bass, lower mids, and treble (a W if you will) and lower the 4k(ish) region. This is not to say that I believe they are the "audiophile" type sound they imply, because they only support AAC and SBC, so there is that.... I think Hifiman knows they whiffed on these, because it appears they have been quietly discontinued (I think). Anyhow, I was just curious to hear some details on why you wanted to replace them (not that I blame you for wanting to mind you).
Bottom line is, they have a great driver in them, they just need some manual work in bringing out the sound they are capable of having.
Edit: I don't know what your preferred sound signature is, but if fitment is an issue, and you find the TWS600 to fit well, then I might recommend the Nuarl N6Pro (or just the regular N6). They are similar in fitment, in that they go into your ears like an IEM would, so you can use any regular tips on them from said IEMs. I use the Final Audio type E on them (the regular, not the new TWS type), and they are super comfortable for many hours. The sound signature is pretty neutral sounding, so if you are wanting something that is more on the fun side, you might either need to EQ a bit or look elsewhere. They also use AptX...
You could get either the N6Pro or the regular N6 because they are the same buds. The difference is that the Pro comes with the Spinfit CP360s, where the regular comes with the Nuarl stock tips. In retrospect, I would have gotten the regular if I had to do it again. Not that I don't like the Spinfits, but I just don't like the Spinfits for the Nuarls (currently using on the MT as mentioned earlier).
My preferred sound sig is neutral with a tad of elevated lows and a little sparkle up top, not so much v-shaped, more like an almost flat chevron shape (if that makes any sense) but for TWS I'm not that picky.
My issues with the TWS600 itself is mostly their complete inability to make a call with both of them in my ears. I always have to take 1 out and hold it up to my mouth for the other side to hear what I'm saying. I just use my TWS for exercise or shopping runs, but I do need to be able to take a call (I'm the emergency contact for problems with the communications systems in multiple large hospitals). The TWS600 need for EQing is just a bit of an inconvenience. Also, their fit is pretty bad because they have the IEM style tips. Like most other TWS in this style I have tried, they have the large diameter nozzles. Usually 5-5.5mm in diameter. and as my earcanal is only 5.5mm at the smallest point (measured off my CIEM), that doesn't leave much space for the eartips. And the TWS600 sticks out pretty far, which I find annoying.
That's also why I'm looking at the MT, it looks like it doesn't stick out as much as the TWS600 and as it doesn't really go in the canal, but over, like my Galaxy Buds, it might just stay put a little better with the fin.
I wish there was a TWS IEM with the Westone/Etymotic/Shure style narrow nozzles, that would solve all my fit issues in 1 go...
