Huh...never noticed the tips weren't circles until you mentioned it. CP360s worked just fine on them (Mediums tend to work in my ears). As long as the measurements are relatively similar to the CP360's shaft and bore, you should be good with any other set as well.I just got these EarFun Free Pro earbuds to replace my aged Anbes 359 (which are bulletproof btw ... I have a NIB set as a backup but haven't needed them). I use them solely to work out, and I'm liking them for that purpose. I have a couple questions:
1. Since the shaft/nozzle isn't round, how do I know what aftermarket ear tips will work? For instance, does anyone know which size SpinFits work? Or any other brand?
2. I had to really turn down the bass. I use Wavelet on my Samsung Galaxy S10. Does anybody have any EQ settings I could compare to? I've got them pretty close to where I want them, but I'm curious how others have tuned them.
Thanks for any info that can be shared.
Yes, they're overwhelming in bass when you come from something neutral. The only EQ settings I've been using are generated based on my ears (I use Neutralizer). If you can swing a few bucks for the app, I wholeheartedly recommend it. Basically gives every pair you own SoundID, wired or otherwise, each with their own individual presets. Think I remember it being 5 USD or less. Alternatively, you could see if someone's made an AutoEQ profile for it and run Wavelet/Neutron instead.
