Hi,
Thanks for your quick review. It seems that you are not happy with your H1, isn't it? I was surprised when you said your phone didn't switch to aptX HD mode! Could it be a bug in the H1 firmware? According to Qualcomm, aptX Adaptive is backwards compatible with aptX HD. Did you force the aptX HD codec in the developer settings of your Z2 Force? I think that the pairing issue could be fixed with a firmware update. Did you report it?
On the other hand, do you know Kenneth Tanaka? If not, it's a japanese YouTube reviewer and he reviewed the H1 and compared it with other earbuds. The H1 did not fare well in a latency test using the gaming mode. Surprisingly, the AAC codec on the AirPods Pro has much lower latency that the gaming mode on the H1! See
THIS video.
Well, I was going to buy the standard H1, but I think I have changed my mind after reading your first impressions.What other alternatives are there with aptX Adaptive, low latency and good sound and fit?
Here is my Kickstarter Feedback:
1) "H1 Premiums arrive today, set them up and little disappointed to see the same cheap pairing as the Sonics in that they try to auto pair each time they are disconnected from a device so not ideal.
Not sure if they remember 2-3 devices like all my other SoundPeats Neckbands or simply forget/repair each time.
Also the App in a nightmare to sign up to as the email box is just out of screen so you cannot type in it, I manage to get my email in by copy/pasting and messing about to finally hit the Verification Button.
I did not see any option to check/update Firmware, they have an EQ setting and a ANC setting which I assume does nothing on these.
Also same as Sonics in that QUALCOMM's claim of aptx-Adaptative being backwards compatible is bollocks as it falls back to aptX on my Moto Z2 Force instead of aptX-HD so if I listen to amazon HD or any Hi-Res it will be stuck with 16/44.1, I would be better of listening on my SoundPeats Force HD in aptX-HD.
The sound is not that great TBH (I would rather disable the EQ fully and use PowerAmp's EQ but you cannot)but the volume unlike the Sonics is pretty loud using SpinFits tips as none of the included tips are large enough for me as like the Sonics they did not include their XL tips.
I also found the FW setting in the SoundPeats App appears in very top of menu before you connect the earphones and disappears once connected, so I assume none are available"
EDIT : They are sounding ok now with SpinFits Tips and I am adjusted to the different sound from my other earbuds.
2) "Fit is far better than the
Sonics, instructions book is for the
H1 not H1 Prem, not a big deal.
So far I discharged them once, not sure if they were fully charged but did say 100% but Right Bud dies with the Left Bus still at 30% which is not great for TWS Mirroring, my
Sonics die within minutes of each other getting in the 0-10% battery range which is great.
I will condition the battery by charging/using/discharge them over the course of the week and test them overnight and I would hope to get at least 8 hours even though aptX on PC as Volume will not be anywhere near 60% for Brown Noise to sleep to."
3) "Again the Right Bud dies at 30%-40% ahead of the Left Bud so about 6-7 hours @ 31% Volume aptX during the night, so I doubt the will do the claimed 10hours @ 60% Volume SBC especially if the Left Bud is doing all the work as the Right seems to have poor battery or is not doing its fair share of the Mirroring.
The Right Bud turns off and the Left Bud keeps working and if you leave it 5-10 mins to recover some battery and turn off the Left Bud and connect the Right Bud it will not auto connect like the
Sonics do in Mirroring Mode instead it will be seen in as an LE headset for you Pair to if you choose (at least I think this is what is going on)."
4) "I now think it is the TWS Mirroring which is not working as it does work fine on my
Sonics on my Android and PC as it is done on the earbuds not the device unlike TWS+.
With aptX @ 80% Volume I took a screenshot as Right Bud died and Left Bud had 40% left, it then took 2 hours (
I set the Android Stopwatch it said 2h 10s) till the Left Bud died so that is not useable no way and a waste of battery if one dies when other is still at 40% which is like the old Master/Slave system.
If you let it rest 5-10 mins you turn it back on you will see the at Left bud 40% and Right bud 10% then a after a few minutes the Right Bud will die again.
I will again try a few charge/discharge session but this looks like a bad battery in the Right bud, the
Sonics can Mirror for each other so if any one is turned off the other after about 1sec takes over and when one dies the other will be at 10% or less and die within 5-10mins of each other but nowhere near the claimed 15hours ' 60% Vol SBC even at 31% aptX."
5) "Got an SoundPeats App update today but it looks exactly the same and still no way to check FW if the buds are connected that menu is not visible and is only visible if buds are not connected.
Adding to the Right Bud continues dropping battery 20-30% ahead of the Left Bud and I now have an Volume issue where it goes really low and the audio sound underwater/muddy like it is in LE Talk Mode (You will see an LE device next to H1 when you pair these).
I can turn Volume to 100% and its not that loud and still underwater/muddy, resetting in SoundPeats App did not fix it also re-pairing with Android and PC did not fix it and nothing fixed it till I did a full reset in the case and re-pairing to Android and PC is needed after doing this.
Today it happened again and I cannot get it to fix so I am done with these, they were rushed without proper testing.
I am back to my SoundPeats Force HD neckband and at least I have long battery (35hours) and I can have the aptX-HD option as QUALCOMM's claim is BS as aptX-Adaptive being backwards compatible as it does not fall back to HD but is on aptX (the same on
Sonics).and reading comments from others for
both Sonics and H1's it is the same on many different makes/models of phones so not me alone.
This was confirmed by Lenovo/Moto staff on their forum, on my Moto Z2 Force aptX Adaptive will not fall back to aptX-HD and will not on any phone unless the phone has both aptX-Adaptive and aptx-HD support.
I had a set of B&W P14's that were also aptX-Adaptive and I though they fell back to aptX-HD but I found out from above staff and using an App to see codecs they have the standalone aptX-HD codec as well as aptX-Adaptive.
So again so much for QUALCOMMS claim of backwards compatibility if you need the manufacturers to pay a license for more codecs."
