clerkpalmer
- Dec 16, 2015
That’s awesome. PSB sound signature is mostly natural, musical and boosted bass. Usually they try to mimic a loud speaker type of sound. These guys know what they are doing, it’s too bad you had to go through the frustration of the initial setup.
I’m planning to place an order as well and pick mine up on Saturday or Sunday.
Just a thought, can you get a small power bank for on the go charging? If it’s possible it might be the cheapest and easiest way as a workaround.
The rep at Best Buy told me that they don’t have a charging module because the battery it much better than Sony or Bose.
Really enjoying the sound signature on these. They are definitely a gym focused set of earphones which was clearly their intended purpose. Ample bass and volume but they still seem crisp up high. Not muddy at all. Probably more well rounded than the bose due to the seal and isolation - these would definitely work as daily drivers. Sound is more natural and less processed - not necessarily good or bad - just different.
